help, check engine light went on
Old Apr 17, 2012 | 10:07 PM
glperez's Avatar
Post help, check engine light went on
i went to autozone and the machine said P0740 and P1491. how do i find out what those mean
Old Apr 18, 2012 | 12:25 AM
P1491 is for the EGR valve lift sensor. It means that the EGR valve is not opening to the proper height. That could be due to a bad EGR valve or the vacuum that controls the valve is not working properly. I would follow the vacuum hoses from the EGR valve to the EGR solenoid to see if any vacuum hoses are cracking/damaged.
You may also want to clean the EGR ports. In the common diy thread on top of the gen tech help forum, there is a link to cleaning egr ports for the 94-97 accords.
The P0740 code is for the transmission. The diagnostics say to fix any other codes first, then check for the transmission code, so fix the P1491 code. When was the last time the transmission fluid was changed? What fluid was used?
Old Apr 18, 2012 | 07:51 PM
glperez's Avatar
thanks dude, i followed the tubes and saw that one was completely off. i reset the computer, just waiting for the cycle to see if it comes back. and as for the tranny, i got it serviced a year ago but i am getting the main seal replaced soon.
Rilex
Mar 19, 2014 05:13 PM
Rilex
Feb 24, 2014 05:33 PM
sc30317
Aug 7, 2012 09:05 AM
misterix
Oct 2, 2009 07:43 AM
