Check Engine Light went on
Old Sep 27, 2009 | 05:50 PM
misterix's Avatar
Default Check Engine Light went on
My check engine light went on my 2000 Honda Accord 4 cyl EX ULEV. I then checked the Manual. It said to make sure the gas cap is tight and drive it for 3 trips. Which I did. Please note I flushed my transmission fluid and had my CPU replaced too b/c of a non starting car earlier this year. Autozone ran a check with their machine and the print out came out with one of these problems, please tell me what I should do:
(Please note because it is not an official Honda machine it could be listed under the wrong manufacturer:
Honda:
Open or shut circuit condition
Poor electrical connection
failed TCC system
Automatic transmission fault
Poor connection at transmission
Internal transmission problem
Infiniti:
Bloced passage in transmission
Faulty TCM
Kia:
Failed damper clutch solenoid
Transaxle fault
Chrysler:
Low fluid level
Poor fluid quality
Defective torque converter cluter
Internal transmission failure
transaxle control system fault
failure of transaxle control modyle
Mazda:
Open or short circuit condition
failed TCC solenoid valve
Acura:
Low transmission fluid level
failed TCC solenoid
Nissan:
check for poor connection
failed solenoid
TCM fault
Sabaru:
TPS misadjusted or faulty
MIL light up request
BMW:
Torque converter clutch circuit open
Mitsubishi:
Failed TCC
Transmission control system - mil request
Volkswagon:
Failed torque converter clutch solenoid
Transmission control system fault
Isuzu:
No communication with TCM
failed TCM
General Motors:
TCM requested mil illumination
The TCM has detected an emission related fault
Eagle:
Transaxle control system fault
ECM received a signal that the transaxle control module has a fault
shorted or opend circuit within transaxle
failure of transaxle control module
Old Sep 28, 2009 | 08:59 AM
You forgot to list the error code number. Look towards the top of the printout, it'll say a number starting with "P", like P0123 or something like that.
Old Sep 28, 2009 | 07:46 PM
misterix's Avatar
P0700 was one of the error codes, the other I am not sure as I wrote them by hand since Autozone's printer wasn't printing it.
Old Sep 29, 2009 | 07:59 AM
P0700 seems to be an overall tranny problem, usually accompanied by something like P17xx which is more specific. Hope someone else chimes in, I'm not much of an auto-tranny guy.
Old Oct 1, 2009 | 02:50 PM
misterix's Avatar
I pulled out FUSE 13 (Clock) on the passenger side fuses and put it back in. The check engine light went off, if it stays off I'll know it was built-in the computer to come on in a certain time if it doesn't I will have to go to a mechanic.
Old Oct 2, 2009 | 07:43 AM
P0700 isn't set to come on at any certain time. But if it doesn't come back, then you know it was just a strange single thing and not a real problem.
Only the maintenance-required lamp is programmed to come on based on simple miles.
Rilex
Mar 19, 2014 05:13 PM
Rilex
Feb 24, 2014 05:33 PM
sc30317
Aug 7, 2012 09:05 AM
glperez
Apr 18, 2012 07:51 PM
