Help How many cats do i have?
Old Mar 5, 2007 | 08:58 PM
HondagalGA's Avatar
Default Help How many cats do i have?
Hi, i have a 99 accord v6 cp with181k and i was wondering if i have one or two converters because i had one (i guess)put on but my cel is on and giving me the same freaking code so i was wondering if it was two or did someone do there job wrong?
thanks much
Old Mar 5, 2007 | 09:04 PM
sir_nasty's Avatar
Default RE: Help How many cats do i have?
I believe you only have one.... however, did they clear the codes after installing it? Are you certain it was the cat causing the problems and not the sensor itself? do you by chance have/know what code it was giving you?
Old Mar 6, 2007 | 12:47 AM
HondagalGA's Avatar
I believe they did because once i got into the car after the repair the cel was off. could it be the oxygen sensor? (i haven't had those checked) i do have to of those right? i was given the p420 code.
Old Mar 6, 2007 | 01:39 AM
PO420 could be the catalytic converter is defective and also caused by your enginemisfiring, not running good or a Large Vacume leak in the system and also Possibally engine oil leakage into the exhaust valve guide seats and passed the piston rings..someone else in the know ..concure with this..?
jasonan
Aug 28, 2009 11:26 PM
deerhunter15252
Oct 27, 2008 05:35 PM
Flatline1121
Jul 8, 2008 08:27 AM
cbrf4i1
Jan 6, 2008 03:22 AM
Julian91
May 2, 2006 09:38 PM
