Help newbe 97 accord
Old Feb 21, 2011 | 01:26 AM
  #21
You can probably dissolve most of that buildup from the coolant by letting that valve soak in vinegar.
You can use a needle, small drill bit, or a thin nail to clean out the passageway. Just try not to bottom where it seats when you tighten that valve. Also, if you have that much corrosion in the coolant system, you may want to run some of the radiator flush to dissolve the buildup likely throughout the system.
Old Feb 27, 2011 | 03:27 AM
  #22
americapitalpaul's Avatar
Thanks PaHonda... I haven't worked on the car for a week now. Gonna try your suggestions out and see what will happen. I'll let you guys know what the result is. Just got a camera so I'm going to take picks and stuff of some of the things I'm working on.
cab4word
Mar 30, 2013 10:08 AM
Superman79
Jul 6, 2011 04:51 PM
94 accord
Jan 8, 2010 11:46 PM
greense
Oct 19, 2009 10:54 PM
superkp13
Jan 23, 2008 08:46 PM
