help! Oil change
Old Dec 18, 2008 | 08:19 PM
quappo
Default help! Oil change
Got my 100k tune-up and the car ran great. Just got a valvoline oil change and wtf? Car is not right! I think I got the basic 1020? Could that be because i didn't get 75k oil or or is valvoline not a good idea?!?!
Old Dec 19, 2008 | 03:43 AM
jerrym's Avatar
Almost A Senior Member
Default RE: help! Oil change
What all was done with your 100K tune up? I doubt oil would do anything, but more likely ignition components like spark plugs/wires, etc.
Can you give some more details about how the car is running.
Old Dec 19, 2008 | 10:30 AM
quappo
Car is screaching during warm up (not common on this car) and seems to be shaking more through lower speeds. I also checked tire depth and it is ok although valvolineinflated to 32 PSI for all. I usually keep it around 30.. It was running very smooth prior and it just seems to be (sound) like it is working a lot harder now then it did in getting up through the lower end speeds @ 2-3k RPM's.
Old Dec 19, 2008 | 11:04 AM
smaglik's Avatar
you need to specifiy what was done at the tune up...
Old Dec 20, 2008 | 12:30 AM
jerrym's Avatar
I agree, need to know all that was done to the car, and where you had the work done (ex. dealer, local shop, etc...)
Old Dec 22, 2008 | 08:36 AM
falkore24's Avatar
Tire inflation info is printed inside the driver side door. Screeching is likely to be from the belts .... perhaps replaced improperly.
PinkFloridaFlamingos
Aug 24, 2011 12:35 AM
chris h
Apr 3, 2011 10:01 AM
ziwang55
Jun 6, 2008 01:25 PM
62maxx
Nov 21, 2006 12:04 PM
