help! Oil change
What all was done with your 100K tune up? I doubt oil would do anything, but more likely ignition components like spark plugs/wires, etc.
Can you give some more details about how the car is running.
Car is screaching during warm up (not common on this car) and seems to be shaking more through lower speeds. I also checked tire depth and it is ok although valvolineinflated to 32 PSI for all. I usually keep it around 30.. It was running very smooth prior and it just seems to be (sound) like it is working a lot harder now then it did in getting up through the lower end speeds @ 2-3k RPM's.
PinkFloridaFlamingos
Aug 24, 2011 12:35 AM
62maxx
Oct 8, 2007 10:00 AM
