Help with resetting SRS light
Old Dec 18, 2007 | 05:01 PM
sir_nasty's Avatar
Default RE: Help with resetting SRS light
was that yellow plug plugged into anything? Not sure on the voltage...
Old Dec 18, 2007 | 08:36 PM
razcob's Avatar
The yellow plug was connected to a yellow base that had two short copper posts in the middle and it didn't appear to be to go anywhere. The picture of the connector is an attachment in my previous post. If there is no voltage at the wires (not the base) then how does it reset?
Old Dec 19, 2007 | 03:01 AM
I noticed that the cover for the connector is black. I think that all plastic wire covers for the SRS system are yellow (I will check my car tomorrow to verify), and it was plugged into a dummy connector like you said.
I followed the instructions that you had, and had no problems. I had to use a thin piece of copper wire, because a paperclip was to thick to jump that connector.
Old Dec 19, 2007 | 09:46 AM
razcob's Avatar
ORIGINAL: PAhonda
I think it is not resetting because I am not getting any voltage. Yes, my plug is yellow and is covered with a black rubber shroud.
Old Dec 21, 2007 | 03:25 PM
razcob's Avatar
Here is a picture of the of the yellow plug, with a black rubber shroud and yellow taped protector. Is this the correct SRS wire to reset?
Also, there are four holes in the plug. Toward the center of the plug, there are two rectangular holes, and toward the outside there are two larger square holes. I have tried jumping both sets of holes. Which holes are the correct ones?
[IMG]local://upfiles/13179/872D109A96D2411AAFB963383E076162.jpg[/IMG]
Old Dec 22, 2007 | 06:12 PM
razcob's Avatar
I reset the SRS light. I found out from the (Acura-Honda Forum) that there are two plugs on the 95 Accord. I was trying to reset the yellow plug near the foot rest and fuse box. The correct plug is located by removing the coin tray and removing its cover panel. The yellow plug is mounted on the left side of the panel.
matnik84
Apr 11, 2011 06:01 PM
renegade05
Aug 10, 2010 10:43 PM
mirgladd
Apr 13, 2009 07:53 AM
99HondaAccord
Mar 31, 2009 10:36 AM
1996AccordLX
Apr 27, 2007 12:14 PM
