high beams wont turn off after wiring disaster
Old Aug 31, 2013 | 08:55 AM
phantomgrey92's Avatar
Default high beams wont turn off after wiring disaster
So my high beams are stuck on since my wiring was shredded due to my fender liner being ripped out by a crack in the freeway. All my wiring for my passenger side lights was ripped out and then rewired but now my high beams won't disengage. Replaced all relays and fuses to no avail. If a positive and negative are switched could that be the cause?
Old Aug 31, 2013 | 11:32 AM
If lights are always On w/ low beam selected, either Light Relay (underhood fuse box) is somehow shorted or wiring short to supply voltage on Red/Yel wire to the lights;
or the On/Off stem switch is shorted closed or wiring short to ground. Check voltage on Blu/Red wire to stem switch w/ stem switch in OFF position. If 0V, then switch is shorted to ground, or 12V switch is open.
If you don't have a wiring diagram, download a manual from Online Manuals post in DIY forum. Any of 90-93 will work for your car.
Old Aug 31, 2013 | 11:35 AM
The problem with tracing wires is my wire tuck. All wires are in the cowl and fender
Old Aug 31, 2013 | 06:25 PM
Fixing problem will require tracing power/ground from original wires to new wires. Likely an improper connection somewhere. Circuit diagram will still help.
otrawj
Feb 27, 2014 03:50 PM
hallstevenson
Aug 1, 2013 11:19 PM
vinom
Jan 26, 2013 07:11 AM
maybeaclunkerbutitsmine
Apr 21, 2012 11:43 PM
zann121
Jun 25, 2009 08:57 PM
