High Idle Issue
Old Dec 30, 2007 | 01:00 AM
HondatechAV6's Avatar
Default RE: High Idle Issue
oh, sorry! it's been a busy few holiday weeks and i've been glued to xbox 360....things look fuzzy everywhere, lol.
Old Dec 30, 2007 | 02:21 AM
eric123's Avatar
ahh 360, it's taken me away from working on me car, very addicting.
Old Dec 30, 2007 | 04:20 AM
JohnL's Avatar
ORIGINAL: HondatechAV6
base idle speed should be 550rpm(+/-50rpm)
a sudden cut off of both ports should stall the engine in my experience.
I'll accept your numbers. Just double checked the specs on my motor (f22A9) and idle is supposed to be 770 +/- 50. Mine doesn't idle that high though, more like 700 and quite smooth. Pulling the IACV connector instantly closes the valve off (so I understand), and on my car at least this doesn't cause it to stall or even nearly stall, though the rpm does drop slightly (should adjust that base idle, but have better things to do!).
Old Dec 30, 2007 | 12:51 PM
oh, base idle = 550rpm +/- 50 rpm. this means the car is fully warmed up, shut it off,iacv is disconnected prior to starting the car, then idle(in a perfect world) would be this number.
now some usless tech info:
if it's not you need to adjust the base idle screw assuming the fast idle valve isn't stuck open for some reason or another and no other leaks.
after adjusting you reconnect the iacv and reset the ecu.
now on start up after a minute or two of running(with the engine already hot) the idle speed should stabilize on 700rpm +/- 50rpm.
now turn on the headlights for a minute or two, idle should now be 770rpm +/- 50rpm.
in gear idle should be 770rpm +/- 50rpm, as well as with the a/c on.
Old Dec 30, 2007 | 12:58 PM
eric123's Avatar
Where is the idle screw? I can't find it.
Old Dec 30, 2007 | 01:29 PM
Old Dec 30, 2007 | 01:37 PM
  #17
eric123's Avatar
OK perfect thats the screw i thought was it but didn't want to go screwing with things.
PepeLePew
Jun 2, 2012 10:49 AM
90pioneer
Apr 9, 2012 09:06 PM
MICHOASTYLE
Mar 15, 2012 06:16 PM
yamahabalu
Sep 28, 2009 02:11 AM
4montecarlo
May 21, 2005 02:50 AM
