Higher rpm's after used transmission installed
Old Sep 18, 2009 | 01:07 AM
sacramentoaccord
Default Higher rpm's after used transmission installed
I had a used tranny installed in my 95 accord 135,000 miles. My concern is that when I hit 70 on the highway my rpm would be around 2,500 now when I reach 70 my rpm gauge reads 3,200. Does this mean it was installed incorrectly? Any input would be appreciated. thanks.
Old Sep 18, 2009 | 09:44 AM
hondadude's Avatar
Sounds like the pressure lever cable is out of adjustment.
The cable that is hooked up to the throttle and goes down to the lever on the front of the trans housing.
I should be adjusted as such:
Back off the 12mm locking nuts and adjust to the point of having slack in the cable, then start to tighten the adjuster so that when you open the throttle and the RPM just barely increases; the pressure lever just barely moves up.
then snug up the locking nut.
DRIVING TEST:
Going along a smooth level road, light throttle at 25 mph, then put the gas to the floor.
The trans should downshift to first gear.
Repeat the same drive, however now at 28 mph. When you floor the gas the trans will downshift to second gear.
Then you should be adjusted correctly to get 'lockup' at highway speed.
Old Sep 18, 2009 | 02:44 PM
sacramentoaccord
thank you for your suggestion I appreciate you're information Sir.
chuckcbb
Feb 21, 2015 09:18 PM
Baxter
Mar 16, 2008 09:58 PM
bil6ly05
Nov 3, 2007 05:48 PM
abhijitgp
Oct 31, 2006 02:15 AM
