honda accord 1.8 vtec wont start
Old Dec 5, 2010 | 08:43 AM
ac1969's Avatar
Default honda accord 1.8 vtec wont start
hi i have a 2001 vtec sport and the clutch went recently,a friend replaced the clutch the other day i have put all the bolts etc back together but now the car wont start,it wont even turn over the dash lights just dim when you turn the key and thats even with a new battery.could it be the starter motor or could it be an immobiliser problem as the bat was off the car all day??please help really need to get this sortid,thanks.
Old Dec 5, 2010 | 09:30 AM
Dimming suggests poor connections.
Bad starter and/or battery connections? Check all connections carefully and secure.
Is the starter solenoid "clicking"? If not, then check for voltage from keyswitch to starter solenoid (small wire to solenoid). If no voltage, a keyswitch problem is likely. If it's clicking, but no starter engagement, the internal solenoid contacts may be worn preventing starter engagement. New contacts, new solenoid, or new starter may be necessary.
Old Dec 5, 2010 | 11:48 AM
ac1969's Avatar
`Thanks for that have checked and its just dimming no clicks,what is strange tho when i put the earth strap back it appears to connect to the gearbox only not gbox and car body so just wondering how its getting earth as all the mountings are rubber although i did run a jump lead from the strap to body and still the same so probably not that.
Old Dec 5, 2010 | 01:45 PM
If solenoid is not "throwing", then check small wire to solenoid for 12V when keyswitch turned to Start position. If 12V is not present, keyswitch may be problem, if 12V is present the solenoid is defective.
eddie1231
Mar 17, 2015 05:16 PM
sayahjames
Jan 20, 2015 07:12 PM
gasface11
Jul 11, 2012 12:33 PM
Jojo97
Jun 29, 2011 06:48 PM
samsungd838
May 14, 2011 08:19 PM
