Honda part# for caliper pin grease/lubricant
Old Jun 6, 2014 | 05:32 PM
wenmang's Avatar
Default Honda part# for caliper pin grease/lubricant
Hi, I am looking for brake grease to lubricate caliper pin and boot. I encountered this video:
which claims that some of product may damage the rubber boot of caliper pin. I am wondering what the part# for such application(grease to lubricate caliper pins) for 2005 honda accord?
Thx
Old Jun 6, 2014 | 06:14 PM
Generally, any high temperature silicone based brake grease should work.
Although you don't necessarily need it, Honda's recommended silicone brake grease is Honda part # 08C30-B0224M - High-temperature, silicone-based grease used to lubricate caliper slide pins. It is expensive though, I have the part number 08C30-B0234M, before it got superseded.
File Type: pdf
Old Jun 6, 2014 | 06:45 PM
wenmang's Avatar
Thx for the reply, do you think that the following is a good alternative?
NAPA AUTO PARTS.
or what do you recommend other than Honda expensive one? Thx
Old Jun 6, 2014 | 06:51 PM
The link you included says it is a silicone spray lubricant.
Probably something like this:
AGS/Sil-Glyde brake lubricant (BK4) | Brake Lube | AutoZone.com
Old Jun 6, 2014 | 07:20 PM
holmesnmanny's Avatar
permatex has a purple bottle of high temp brake grease its like $15-20 its the best
JOE.G
Jun 12, 2013 10:02 AM
jkowtko
Oct 28, 2012 09:48 PM
tdockdur
Jan 23, 2011 08:55 PM
EXV6NIGHTHAWK
Mar 7, 2010 04:12 PM
tradosaurus
Apr 30, 2008 03:49 PM
