Horn problem
i have a 95 accord lx 2.2. my horn stopped working a little while ago so today i decided to investigate it a little bit. The horns themselves work i connected them both to my battery and they sounded. The fuse is brand new and the steering wheel button clicks. What could be the problem? horn switch?
Next, take a test light and check for power on the horn wiring before the horn connector. Have somebody push the horn button while you are testing the power from the relay to the horn.
to add to piggy's post-the LT GRN/BLU wire should be ground when the button is pressed....allowing the ground to flow from the BLK to the BLU/RED which is the ground at the horns.....this does have SRS, correct?
