Horn problem
Old Sep 4, 2011 | 02:29 PM
Et5291's Avatar
Default Horn problem
i have a 95 accord lx 2.2. my horn stopped working a little while ago so today i decided to investigate it a little bit. The horns themselves work i connected them both to my battery and they sounded. The fuse is brand new and the steering wheel button clicks. What could be the problem? horn switch?
Old Sep 4, 2011 | 02:39 PM
bigpat's Avatar
Almost A Senior Member
Look for a horn relay in the fuse box panel...Have a friend push the horn button while you listen carefully to the relay...It should click. If not, then I would change the relay.
Old Sep 4, 2011 | 02:40 PM
Et5291's Avatar
when i hit the horn button i hear it click
Old Sep 4, 2011 | 04:06 PM
piggylover1985's Avatar
Check the power and ground wire to the horn.
Old Sep 4, 2011 | 04:45 PM
bigpat's Avatar
Next, take a test light and check for power on the horn wiring before the horn connector. Have somebody push the horn button while you are testing the power from the relay to the horn.
Old Sep 4, 2011 | 07:25 PM
Et5291's Avatar
the test light is only working on one of the connectors, and that one is always hot. the the other one does not light up when the horn is pressed
Old Sep 4, 2011 | 07:36 PM
It use the other wire to complete the circuit which is ground, when you push on the horn it should give you a ground. Check it for ground.
Old Sep 5, 2011 | 07:04 AM
to add to piggy's post-the LT GRN/BLU wire should be ground when the button is pressed....allowing the ground to flow from the BLK to the BLU/RED which is the ground at the horns.....this does have SRS, correct?
Old Sep 5, 2011 | 08:06 AM
Best way to check is by using a volt meter, because a test light will light up with only a few volt.
mvickky
Dec 21, 2007 11:04 AM
faosh
Nov 13, 2007 04:26 PM
foulmouthedleon
Nov 11, 2007 06:49 PM
Jaeger
Oct 19, 2007 12:48 PM
chronchameleon
May 12, 2006 12:47 PM
