How could they screw it up?
Old Sep 14, 2013 | 07:51 AM
wunderbra's Avatar
Default How could they screw it up? 97 accord
A few months ago, I took my 97 wagon in to a local shop for a timing belt job. Immediately afterward I felt a little vibration, as if a motor mount was bad or the exhaust was hitting. I took it back and they checked it out and could not find anything. Before that the engine was smooth as silk. Now last week, the alternator/ac belt started squealing. I looked and the long bolt that mounts the alternator was not even there! I took it back again and he installed a bolt and tightened the tensioner. A few days later, squealing again. I looked the tensioner bolt was loose. This time, I just loosened the mount bolt, tightened the tensioner and re-tightened the mount bolt. That lasted two days before the tensioner became loose again. What could they have screwed up to make that tensioner keep coming loose? I can't find a diagram of that part online, but I may need to buy one, Also, when he loosened that driver side engine mount, is there something he might have done wrong putting it back together to cause the vibration?
Old Sep 14, 2013 | 08:27 AM
EXV6NIGHTHAWK's Avatar
I would keep taking it back, until they fix their screw ups. I guess it could be a few different things. Timing belt installed one tooth off? Mount broken or installed incorrectly? Wrong size bolt for the alternator? If they have any pride in their work, they will make it right. Good luck
Old Sep 14, 2013 | 11:37 AM
Not sure if this pic will help or not?
If they got the balance shaft timing off - then you could have a strange vibration.
I would still check all of the mounts to be sure that one or more is not broken.
husky100
Jan 1, 2008 06:30 PM
octaviusprime
Jun 17, 2007 09:25 PM
RoKnAzn
Apr 4, 2007 05:50 PM
kbrown@insystcom.com
Feb 27, 2007 05:07 PM
rickydelcid
Nov 13, 2006 12:38 AM
