How do I change CVT fluid, 2013 EX-L
Old Jul 22, 2014 | 09:12 AM
1staccord's Avatar
First, if you invested good money for a new car why would you want to save a few dollars on oil to protect the most expensive repair item? I personally try to change every 6,000 miles and for the first 10-15,000 miles change the filter only at about 3,000. Just a hunch but I suspect the filter to be the weak link in this whole equation. Note, the '04 Impala I "inherited" from my wife just turned over 300,000 all original miles with no engine or transmission problems.
Old Sep 25, 2014 | 06:02 AM
Just for clarification to readers of this thread, the youtube video in post #7 is for an engine oil and filter change, different that the CVT fluid change. That was to answer pryna66's three part questions in post #6 of this thread.
Old May 12, 2015 | 09:56 PM
posativJ311's Avatar
How about a picture picture of the filler hole?
This is very much like my '07 manual trans, and I love it. Its easy to change its fluid.
Old May 12, 2015 | 10:05 PM
It is shown in my post #3.
Old Dec 15, 2015 | 11:17 AM
ACERX's Avatar
Default The amount of CVT fluild (2014 Honda Accord automatic)
RedBull & ALL,
your information has been very educational for me and right on point for newbie. I 'm convinced that i can complete the CVT transmission fluid Drain/ Fill. However i have question, you did mention that automatic transmission on the 2014 Honda Accord has capacity for 3.5 Liters, now the question i have is, would it be an issue if its not exact? would it cause a problem if i put in 4 quarts instead? i know sometimes with oil change there is wiggle room, just wanted to check with all before i land myself in a bill for transmission fix.....please provide insight.
Old Dec 15, 2015 | 06:48 PM
Follow the instructions in my post #3 regarding proper checking of fluid level and do not overfill the transmission.
This is an image from that same post, it shows the relative amount of fluid for that would be between the upper level and proper level (i.e., about 0.1 L (0.1 U. S. quart). It is normal for the fluid to be between the upper level and proper level. Also, note that a liter is more in volume than a U.S. quart.
Attached Thumbnails How do I change CVT fluid, 2013 EX-L-12994d1395417684-how-do-i-change-cvt-fluid-2013-ex-l-check-refilling-cvt-fluid.jpg
Old Dec 25, 2015 | 03:09 PM
  #17
ACERX's Avatar
Default Check Transmission Level Bolt
Redbull,
I followed your instructions everything worked perfectly like you have noted just have two questions
1. I measured the amount of transmission fluid that came out and it was exactly 4quarts is that normal, so naturally I replace the exact amount ( I measured the amount of transmission fluid that came out )
2. The fluid level check bolt, I opened it and fluid came out athen it driped and went to drops and then stopped, is that what should have happened?
Please help! Happy Holidays!
Old Dec 25, 2015 | 03:41 PM
  #18
You do not have to wait till it stops; a slow drip is optimal. However, even though it stopped, if the vehicle was relatively level, the CVT fluid would still be at the "proper level" as shown in the instructions.
In other words, probably no need to worry about it. Happy Holidays.
Old Mar 17, 2019 | 11:23 AM
  #19
Matt Bova's Avatar
Originally Posted by 1staccord
Thank you ALL for the complete information, just had the CVT (complete) replaced under warranty @ 28,000 miles. Thanks again
what was wrong with your cvt that they replaced it?
Old Dec 12, 2019 | 09:02 AM
  #20
Icthelite's Avatar
Here is another YouTube video I found very helpful
newHondaUser
Jun 7, 2024 09:23 AM
62maxx
Oct 18, 2015 08:20 AM
BPRescue
Nov 8, 2013 09:09 PM
BoloMK34
Mar 31, 2013 08:00 PM
broker80
Feb 14, 2013 09:11 AM
