How do I disable the A/C compressor on a 1992 Honda Accord?
Old Nov 17, 2012 | 03:50 PM
blakem's Avatar
Default How do I disable the A/C compressor on a 1992 Honda Accord?
My compressor has seized. Until I get it fixed, is there an easy way to disable the compressor? I'm afraid someone will hit the a/c button causing the belt to just slip on the pulley. I couldn't find a fuse for the compressor under the hood. Is there a fuse somewhere else or something I can unplug?
Thanks in advance for your help.
Old Nov 17, 2012 | 07:45 PM
Just unplug the one pin connector going to the compressor. Secure the wiring harness with a zip tie or piece of wire, because it could get caught in the belt or the cooling fan. I think the wire color is red, but not 100% sure on that.
Old Nov 18, 2012 | 01:17 AM
holmesnmanny's Avatar
All you gotta do is get a belt that fits the power steering pump and alternator.
Old Nov 18, 2012 | 08:39 AM
Be sure to put elect tape on the end of that wire.....it goes "hot" if the button is pushed.....don't want to short out anything.
Old Nov 19, 2012 | 12:37 AM
Just need to clarify, I meant one for the power steering pump and one that fits only the alternator. All you gotta do is use a piece of string to measure and go to the parts store and match it up.
Old Nov 19, 2012 | 10:22 AM
Seems like we have 2 different suggested methods & confusion combining them together.
1) Leave the compressor in place and absolutely disable it so it can't be turned on. For this to work, the clutch has to be OK to freewheel.
Unplug the wire from the compressor clutch, and tape it up. Make sure the end is covered so it can't touch ground & short out. Make sure it can't get caught in the rotating belts.
2) REMOVE the compressor & get an alternate belt. You can measure it, or you can ask for a belt to fit an Accord DX (which I think doesn't have AC).
ak474u
May 4, 2015 11:15 PM
SixtyMac
Dec 25, 2012 03:15 PM
Wiley-X
Apr 2, 2011 11:14 AM
muhleebbin
Apr 16, 2010 12:45 AM
rEEd E.
Aug 12, 2006 04:06 AM
