How do I properly wash my new 2012 Accord LX-P?
Old Dec 12, 2011 | 07:00 PM
accordhybridowner's Avatar
Originally Posted by ctbear
Picked up The Absorber for $9.50 and a gallon of the turtle zip wax/wash for $5 at Walmart. Damn that Absorber is pricy..but it's made in Japan...better be worth it lol.
Now, I just need to look for that Meguiar's Microfiber Wash Mitt locally somewhere... it seems to be highly rated on Amazon:
Code:
http://www.amazon.com/Meguiars-X3002-Microfiber-Wash-Mitt/dp/B000RXKR6M/ref=dp_cp_ob_auto_title_1
I actually prefer a wash sponge, which will hold some water. I like to fill up a bucket with soapy water, then dip the sponge into it. Kinda like washing dishes, but without the dish detergent
Old Dec 14, 2011 | 10:10 AM
Scottwax's Avatar
Here you go. I've had my own detailing business since 1994, I wrote this guide up several years ago (update it as needed) and it included my youtube video links that show how to wash, clay, apply sealants, use DA and rotary polishers, etc.
First, I'll tell you how to wash and wax your car in an hour or less. This does not include any polishing so this method won't correct any defects. However, if your car is in good condition already or you just want it clean and protected, this method is excellent.
Products you will need:
2 gallon capacity bucket
1 wash pad, I like to use microfiber covered foam pads
4-5 16" x 16" microfiber towels
2-3 terry cloth or cotton towels (only for wheel, fenderwell use, NOT FOR PAINT)
Wheel brush(s)
Tire protectant
Glass Cleaner
Optimum No Rinse Wash and Shine: No Rinse Wash and Shine - car wash that doesn't pollute the environment
Optimum Car Wax: Eco Car Wax - protects your car from sun damage and protects the environment
Video links at the bottom of this post on how to use Optimum No Rinse, Opti-Seal and various tire/fenderwell and claying videos
Steps:
1. Using a capful or approximately one half ounce of Optimum No Rinse (ONR), add it to one gallon of water in the bucket.
2. Clean your wheels, tires and fenderwells using the ONR mixture and your brushes, wipe dry with the terry cloth towels.
3. Dress the wheels and fenderwells with your tire dressing-and don't forget the fenderwells! Dirty fenderwells detract from an otherwise clean and shiny car!
The reason to do the wheels and fenderwells first is so when you apply the tire dressing, any overspray will be washed off the car during the washing step.
4. Empty out your bucket and refill with clean water, adding one half to one full ounce of ONR (less if relatively clean, more if really dirty).
5. Using a chenille covered foam pad or a wash mitt, wash one section of the car at a time and dry immediately using two microfiber towels, one for the first drying pass and making sure you leave a little moisture behind, use the other towel for a second drying pass. If you get the panel completely dry with the first towel, then don't go over it with the second towel because rubbing even a soft microfiber towel on dry paint can leave streaks.
Once you get the process down (it may take a couple washes to really nail it) you should be able to wash the body of your car in 20 minutes or less unless it is really filthy.
6. After washing open your doors, gas cap door and trunk or hatch and wipe down all the jambs.
7. Using Optimum Car Wax (OCW), spray onto a section at a time. Don't soak the panel, just a mist should do. Spread the wax over the panel, flip the towel and wipe to a haze free shine. If you can use a detail spray, you can use OCW, it is that easy. Depending on your area, wash habits, etc, you can expect 3-5 months durability. Honestly though, it is so easy to use you will probably use it every few washes. Shouldn't take more than 10 minutes to do the whole car. In fact, you can also apply it as you dry each section when washing with ONR to save even more time, or apply while washing and apply a second coat for even better protection with very little additional time spent.
8. Clean your glass inside and out.
Stand back and admire your shiny car! Take pics and post them on OT!
There are several vendors who carry Optimum products, the one I would recommend first is www.exceldetail.com because he is an OT member and I believe we should support each other, plus he ships very fast, has excellent customer service, is an all around nice guy and he also carries a fine selection of microfiber towels, the rest of the Optimum product line as well as Clearkote, Poorboys, 4 Star, Propel buffing pads, etc.
Another excellent vendor is Aloha & Welcome to Our Oasis for All Your Auto Detailing, Auto Detailing Supplies, Auto Detailing Equipment, Auto Detailing Products, & Auto Detailing Accessories for all your Automobile Detailing or the Eco Car Care - Green Car Wash Products site, autogeek, etc.
Scottwax's Offical Comprehensive Detailing Guide®
HARD SUPPLIES
- Wet/Dry Vacuum (>1.5 HP) w/ an assortment of nozzles and a thin crevice tool
- Bucket
- Spray nozzle-if washing conventionally
- Microfiber covered foam pads, or wash mitts
- Wheel brush, thin brush for tight areas, interior brush w/ soft bristles
- Terrycloth towels (wheels, tires, fenderwells)
- Microfiber towels (washing, removing product)
- Foam applicators (wax application)
- California Car Duster
- Q-Tips (Cleaning Vents)
Optional for power buffing:
-Porter Cable 7424 XP, Meguiars G110 v2, Griots DA polisher
-An assortment of 6.5" finishing, polishing and cutting pads. Polishing pads are your workhorse. The new microfiber pads that Optimum and Meguiars have are terrific, some softer paints may require foam finishing pads still.
Detailing products
I have listed products I have personally used.
No Rinse Washing
Conventional Washing
Optimum Car Wash
Poorboys World Super Slick & Suds Concentrated Car Wash
Mothers California Car Wash
Meguiars Gold Class or NXT Car Wash
Kit Carnauba Wash
Duragloss 901
--honestly, any quality car wash soap should be fine. Do not use dish soap!. It strips wax from your paint and dries out your rubber seals and trim. Regular use will also dry out your paint.
Drying
Microfiber towels.
Wheel Cleaners
Personally, I don't use wheel cleaners. I prefer to use either ONR or when washing conventionally, car wash soap. If you keep your wheels clean there should be no reason to have to use a wheel cleaner. Improper use (as in not following directions and apply to a hot wheel) or using the wrong wheel cleaner on your rims can damage them and require refinishing to correct.
Clay Bars
Most of the clay bars now available are made by Clay Magic since they hold the original patent and sued the crap out of anyone who copied their clay-so really, the brand doesn't matter much.
Clay bars removing imbedding grit, contamination, tree sap, paint overspray, etc from your paint. If you run your hand over your just washed paint and it has a gritty feel at all, you need to clay. This will pull all that gunk out of your paint leaving it glass smooth.
Spray a quick detail product (usually clay kits include the spray) onto your paint (about a 2' x 2' section) and rub the clay bar using moderate pressure over the paint. When it glides effortlessly and quietly over your paint, wipe off the clay lube and move on to the next area. Optimum No Rinse works as a clay lube, or you can clay as you wash with ONR since it slicks the paint up enough.
Polishes and compounds
My favorite polishes and compounds are:
Optimum Hyper Polish and Hyper Compound (sprays), Optimum Compound II (heavy cutting), Optimum G-P-S (polish, glaze and sealant in one)
Meguiars #105 Compound, #205 Polish, D300 Compound (designed to work with their Microfiber pads), D301 Finishing Wax (final polish and protectant in one)
Menzerna Intensive Polish and Final Polish
3M Ultrafina #06068, works amazingly well with the blue 3M Ultrafina pad for swirl free rotary work
Use by hand:
Use a microfiber towel, folded into 1/8ths size to form a thick pad and so you can apply even pressure. Use moderate pressure, enough to build up some warmth on the towel and work the product into the paint until it looks nearly clear and dry, then wipe off immediately. Refold the towel and move on to the next section.
By Porter Cable polisher
Using a polishing pad, apply a circle of product about 1" from the edge of the pad and for the first couple of areas, before turning on the PC, spread the product over a 1' x 1' area to prevent dry buffing. With the pad pressed lightly against the paint, turn on the PC and set it to '5' and spread the product over a 2' x 2' area using moderate pressure. Kick the speed up to 6 and slow down your passes to about 1/2-1" per second with 50% overlapping passes, up/down, across, diagonally. Use enough pressure to lightly bog the PC and then back off just enough to pick the speed back up. Work the polish until it begins to clear or dry. Wipe off excess product, inspect your work, one or more additional applications may be needed with heavy defects.
Always start with a medium grade polish and a polishing pad and step up the aggressiveness of the polish before moving up to a cutting pad.
Final Polishes and Glazes
You will use these to further refine your finish or if the paint is in good condition and you just want to add more depth and pop to the finish prior to waxing.
Optimum Polish with a finishing pad can be used as a final polish
Clearkote's Vanilla Moose and Red Moose Machine Glaze
Menzerna FPII or PO106FF (at $50 a quart!)
Poorboy's Professional Polish or Polish with Carnauba
Jeff's Werkstatt's Prime, Prime Carnauba or Prime Strong
Klasse All in One
Just a suggestion-You can mix in about 30% of Clearkote's Red Moose Machine Glaze into either Menzerna polish to cut down on dusting and add more depth to the super clear wet shine of Menzerna.
Waxes
As a rule, waxes have a deeper, more liquid look than sealants, protect a little better against bird bombs but need to be reapplied more often than sealants.
Clearkote Carnauba Moose
Optimum Car Wax
Poorboy's Natty's and Natty's Blue Paste
Meguiars #16 (discontinued, you may be able to find a few vendors who still have it, still sold in the UK though), #26 in liquid or paste
Collinite 476 Wax
P21S or S100 Paste Wax-the S100 is essentially the same as P21S but widely available at Harley Davidson dealers and costs less too!
Pinnacle Souveran-yeah it is $70 but amazing on black and red paint, good for 50+ applications
Jeff's Werkstatt Carnauba Jett-spray carnauba
Sealants
Optimum Opti-Seal
Jeff's Werkstatt Acrylic Jett and Acrylic Jett Trigger (Trigger is in spray for, extremely easy to use).
3D HD Proxy
Detailer's Pride Poli-Coat Sealant
4 Star Ultimate Paint Protection
Klasse Sealant Glaze
Meguiars #20 Polymer Sealant, NXT High Tech Wax, or #21 Sealant
Quick Detail Sprays
You can use these after washing to give you the 'just waxed' look.
Clearkote's Quikshine
Optimum Instant Detailer or ONR mixed down at 1.5 oz per 32 oz
Jeff's Werkstatt Acrylic Glos-meant to be used with the Werkstatt system, but should be fine over any sealant
Meguiars #34 Final Inspection
Interior Cleaning Products
I use an 20:1 mixture of water and Woolite HE (the laundry soap version) in a spray bottle as my interior cleaner (8 parts water, 1 part non HE Woolite). You can use it on leather, vinyl, carpet, fabric, etc. Spray, scrub with a small brush with nylon bristles as needed, wipe up and wet vac as needed.
Meguiars and several other manufacturers have great all purpose cleaners that are safe for most interior surfaces but read the label first! I'd only recommened the water/Woolite mixture for leather though.
Interior Protectants
Vinyl, rubber and weather stripping-
Optimum Protectant Plus
Meguiars #40, Meguiars Interior Quick Detailer, Natural Shine Vinyl & Rubber Protectant
Poorboy's Natural Look Dressing
Armor All Original Shine
303
Vinylex
Leather-
Meguiars Gold Class Leather Conditioner
Turtle Wax's Leather Cleaner and Conditioner
Tanner's Preserves
Lexol
Leather Master's Leather Vital (it ain't cheap!)
Miscellaneous
Glass cleaners:
ONR at QD (1.5 oz per 32 oz of water) strength
Meguiars NXT Glass Cleaner
Eagle 20/20 Class Cleaner
Stoners Invisible Glass
Tire/fenderwell dressing:
Poorboy's Bold N Bright Tire Dressing
Optimum Tire Shine
Meguiars Hyper Dressing (can be cut with water up to 4:1)
Trim dressing:
3D Trim Protecant
Meguiars #38 Tire and Trim Gel
Poorboy's Trim Restorer
Mothers Back to Black
Engine Cleaning
1. Make sure engine is warm, but not hot. Cold engines are harder to remove grease and oil from.
** Check the directions on the engine cleaner/degreaser you are using, though. Some specifically say to clean the engine when cold only. **
2. Cover your distributor (if you do not know what or where it is, get a manual for your car), alternator and fuse box. Most electronics under your hood are adequately sealed for rain water splashing up on them, but high pressure water is another story.
3. Spray Greased Lightning's Orange Blast (my preferred engine degreaser) liberally all over your engine and engine bay. Let it sit for about 5 minutes. If your engine is really dirty, then after the 5 minutes, spray it down again and wait an additional 5 minutes.
4. Spray the engine and engine bay with high pressure rinse water - but even though your distributor may be covered, still use lower pressure around it to be on the safe side.
5. Any remaining grime, spray again with Orange Blast, and use a stiff brush if needed. Rinse again.
6. Remove the plastic coverings and start the engine. Let it run until it is dry. You will have to dry the painted surfaces in the engine bay and the underside of the hood with a towel.
7. Dress any hoses, etc. you want with rubber/vinyl dressing.
Any detailing questions? We have a detailing forum here at Off Topic:
That'll Buff Right Out! - Offtopic.com
In addition, there is a detailing specific forum called Autopia- http://autopia.org
Please do not e-mail or PM me detailing questions, post them in our forum or in this thread and PM me the link only.
Videos of me using Optimum No Rinse:
How to apply Opti-Seal
Carpet cleaning using a Cyclo brush attachment and a Meguiars G110
Fenderwell cleaning with ONR and a pesticide sprayer
Claying with Optimum No Rinse at wash strength
Cleaning wheels with ONR
Cleaning wheels with ONR and Optimum Power Clean
Proper Rotary technique
Headlight polishing using a Meguiars G110 DA buffer
Old Dec 14, 2011 | 10:17 AM
bigpat's Avatar
Almost A Senior Member
WOW----That was an impressive post !!
Old Dec 14, 2011 | 06:39 PM
Very nice post regarding detailing... Thanks.
Old Dec 14, 2011 | 09:02 PM
I'm still not sold on powerwashing a car's engine. Has anyone ever seen an engine gone bad due to not receiving any bath?
Old Dec 14, 2011 | 09:37 PM
To be objective, take things with a grain of salt. It doesn't mean everyone has to necessarily agree with everything said; however, the poster is giving a lot of good info. in his post and should be given credit for it.
No offense intended; but, let's not be a Debbie Downer, at least on this forum.
Old Dec 14, 2011 | 10:03 PM
  #17
Ah, of course the long post was amazing , obviously a rarity! I meant to only question the idea of engine washing in general. It's been brought up around here some time before.
Old Dec 15, 2011 | 10:19 AM
  #18
ctbear's Avatar
I've heard that it may cause possible fluid leaks due to the natural sealing nature of the grease, gunk, etc. around the seals, which some say is good and part of the "breaking in a new car" thing.
Old Dec 15, 2011 | 10:21 AM
  #19
ctbear's Avatar
Wheel brush(s)
Tire protectant
Glass Cleaner
Steps:
HARD SUPPLIES
- Bucket
Detailing products
No Rinse Washing
Optimum Car Wash
Kit Carnauba Wash
Duragloss 901
Drying
Microfiber towels.
Wheel Cleaners
Clay Bars
Use by hand:
Klasse All in One
Waxes
Optimum Car Wax
Collinite 476 Wax
Sealants
Optimum Opti-Seal
3D HD Proxy
Quick Detail Sprays
303
Vinylex
Leather-
Tanner's Preserves
Lexol
Miscellaneous
Glass cleaners:
Optimum Tire Shine
Trim dressing:
3D Trim Protecant
Engine Cleaning
Washing with Optimum No Rinse - YouTube
Optimum No Rinse Wash beading - YouTube
Applying Optimum Opti-Seal - YouTube
Carpet cleaning - YouTube
Fenderwell cleaning with Optimum No Rinse Wash - YouTube
Claying with Optimum No Rinse - YouTube
Optimum No Rinse and wheels part 2 - YouTube
Wheel cleaning with Optimum No Rinse Wash - YouTube
Optimum No Rinse and wheels part 1 - YouTube
Proper rotary technique when using Meguiars #205 - YouTube
Headlight polishing - YouTube
THANK YOU SO MUCH! for the awesome post
But what is your opinion on the Turtle Zip Wax/Wash solution that I will be using? You seem to like Optimum products a lot...
grim_reaper
Aug 9, 2012 12:21 PM
WICKEDPHOTO
North East
Feb 16, 2012 02:33 PM
Blue Devyl
Feb 12, 2012 07:25 PM
SirJohnIII
Mar 21, 2011 02:09 PM
