How many turns on Throttle Body Screw
Old Jan 1, 2008 | 04:47 PM
husky100's Avatar
Default How many turns on Throttle Body Screw
I have been battling an ongoing throttle body problem. With the up and down idle. I never touched this screw however it is for some form of adjustment. I screwed it in and counted 2.75 turns. I backed it out the same amount. I started the car and again the up and down idle started but this time I screwed it in 1.25 turns and it ran smooth. During road test it started again. I screwed it in .75 turns and again it stopped the loping idle. What is the factory setting??
Old Jan 1, 2008 | 06:30 PM
HondatechAV6's Avatar
Default RE: How many turns on Throttle Body Screw
there is no factory setting. this screw is used to adjust the base idle speed. every car is slightly different, so it's probably adjusted a slightly different amount on every car. if you adjusted base idle wrong and just turn the screw with the engine running, you'll just cover up a problem elsewhere.
curtie94
Apr 20, 2012 06:25 PM
Al_S
Jun 26, 2010 08:17 PM
jasonan
Aug 28, 2009 11:26 PM
mikel6690
May 9, 2007 02:45 PM
TedsF23accord
May 30, 2006 01:30 AM
