How to tighten the throttle cable for a 06 Accord?
Old Oct 12, 2016 | 06:42 PM
mike.zhang's Avatar
Default How to tighten the throttle cable for a 06 Accord?
I found the gas pedal of my 06 Accord is loosen, how can i tighten it? It seems the throttle cable is connected to a black box (the position sensor?), there are no bolts to tighten this cable, how can i do that?
Thank.
Old Oct 12, 2016 | 09:29 PM
It looks like you can take up some of the slack of the cable from the gas pedal to the accelerator position sensor (app sensor) under a cover on the passenger side of the firewall. It has to be near the app sensor.
EDIT: Be sure to leave some slack in the cable, or the sensor will think you are pushing on the gas pedal.
You may want to have an assistant slightly push on the gas pedal to see if you get movement at the apps sensor before adjusting.
pr1madona
Feb 23, 2014 11:26 AM
rykertest
Feb 1, 2012 03:27 PM
clutch811
May 24, 2008 09:35 PM
rloden
Apr 5, 2008 07:47 AM
Mrheat
Nov 11, 2007 08:12 AM
