i get a small pull when going to 1st gear.
Old Nov 8, 2011 | 02:45 AM
Spidey's Avatar
Default i get a small pull when going to 1st gear.
I have no idea what this problem is I have a 94 Honda Accord LX, and i get a small pull or a little jump every time I go into first gear. My car is automatic 5 speed I have no idea if its the motor or the transmission. I was looking for some help to get it fix at the lowest price posible. I just need to pin point what the problem is. Any help will be greatly appreciated.
Old Nov 9, 2011 | 11:06 PM
UhOh's Avatar
My '97 AT does that too if I shift into 1st from N while engine is idling.
I consider that normal and healthy, but maybe I don't understand...
Old Nov 10, 2011 | 05:38 PM
lmrj0030's Avatar
i heard our 97s are suppose to be known of it's rough gear shifting/changing. no clue about the 94s. but i guess since they're from the same gen it should be the same?
Old Nov 10, 2011 | 10:30 PM
I would inspect the motor mounts to see if there is engine movement.
Old Nov 10, 2011 | 10:42 PM
Spidey's Avatar
I think I will check the motor mounts. My 94 is an automatic not a manual shift. Thanks keep the ideas comming please. I will check the motor mounts in the morning. Thanks guys
letsclique
Jun 18, 2016 04:29 PM
vetski179
Apr 13, 2015 02:27 AM
premiratl
Apr 5, 2011 01:25 PM
ziggy!talon
Apr 10, 2008 02:45 PM
cj_trap_shooter
Mar 22, 2007 02:58 PM
