I think I broke something! (Master door switch, window motor, and more!?) -[Solved]
You can use something like a T pin, available at Walmart, etc., and backprobe. These pictures are just to give a picture of the concept of backprobing without piercing any wires.
https://www.hondaaccordforum.com/for...%5D-t-pins-jpg
https://www.hondaaccordforum.com/for...back-probe-jpg
So I probably found my issue.. This is my yellow wire on the door side of the 10p connector. It broke somewhere in the rubber sleeve. I was attempting the tests described above and noticed the wire felt loose. I will fix and see what happens!
Not sure how I didn't notice before... The connector seemed ok yesterday lol
Edit: I made a small incision in the rubber and used a few pairs of tweezers to fish the wire out. I then held both ends together and when I pressed the lock/unlock button it worked!
redbull-1 Thank you very much for the help, I really appreciate it. I'm stoked to be able to use my window and door!
therivler1
Feb 12, 2008 08:10 AM
