Idle Problems
Old Aug 21, 2009 | 06:45 AM
Squeeze the radiator hoses when the engine's cold. You should be able to hear sloshing if there's any air in the system. The only thing you SHOULD hear is the little rattle-pin in the thermostat.
You need to not only reset the ECU, but let it re-learn the idle system behavior.
Let it cool off & reset the ECU.
Start the engine without touching the gas pedal.
Let it warm up completely without touching the gas pedal.
Old Aug 23, 2009 | 12:04 AM
Pauper
Alright, thanks. I will check the radiator for slushing tomorrow, but I did reset the ECU and let it idle for ten minutes, drove it around.. and the idle started to flucuate one time. It does it WAY less then it did before, but it does it time from time. IDK what to do anymore =/
Old Aug 23, 2009 | 12:42 AM
deserthonda's Avatar
https://www.hondaaccordforum.com/for...ead.php?t=7848
also make sure that the pcv valve is not leaking
Old Aug 26, 2009 | 10:19 PM
Pauper
damnit, i bled the radiator .. seemed like it was working fine, then i give it gas in park and it idle starts flacuating between 1 - 1.5 rpms again .. it started to do it more often AFTER i bled it then it did before .. idk what to do ......................................... AHHHH
Old Aug 27, 2009 | 07:30 PM
Have you cleaned the throttle body bore and both sides of throttle plate. A dirty throttle bore and plate can starve engine for air and might set up an idle oscillation as engine trys to achieve stable idle.
Also if someone adjusted the throttle plate stop screw (should never be adjusted) in an attempt to reset idle speed, this might also cause an unstable idle.
HatchJunki
Mar 9, 2013 08:23 AM
90pioneer
Apr 9, 2012 09:06 PM
RWilliams
Jul 24, 2011 09:16 PM
fperezal
Jun 14, 2006 05:03 AM
KimberlyC
Apr 16, 2006 11:51 AM
