Idle surge problem please help!!!
Old Nov 22, 2010 | 08:11 PM
jdmasf_ck's Avatar
Default Idle surge problem please help!!!
Ok so i have a 94 accord and my idle surges only at a stop and its driving me nuts, it only does it when its cold outside, ive tried two different iacv valves fast idle thermal valves ive cleaned them and nothing helps, i had the timing belt,water pump, and radiotor done recently so i no its not a coolant problem, but it does have an aftermarket intake and i noticed whoever put it on removed the iar but left the solenoid, does anyone have a clue ecu maybe?
Old Nov 25, 2010 | 12:22 AM
IH8SPM's Avatar
Bleed out the air in the system and replace your thermostat you have checked the other recomendations.
Old Nov 26, 2010 | 03:48 PM
jdmasf_ck's Avatar
like i said ijust had the radiator and water pump replaced by honda so i dnt think it needs bled out but ill give it a shot, but why a thermostat?
Old Nov 26, 2010 | 06:12 PM
Check that PCV is checking air flow. If PCV is stuck open, this can cause a loping idle.
eckhart
Sep 30, 2012 08:52 AM
stinkbugjoe
Apr 23, 2009 03:22 PM
h22q
Dec 20, 2007 02:07 AM
longpatch
Nov 19, 2007 07:48 PM
ADub
Jan 20, 2007 05:18 PM
