immobilizer problem 2003
Old Oct 4, 2017 | 10:06 PM
Justin Douthit's Avatar
Default immobilizer problem 2003
03 Honda accord ex, green key symbol flashing. Had locksmith come out two days and could not get even a new key to program. If the imobolizer at key ignition was bad could it keep you from programming key and can I replace the imobolizer at the ignition and lock Smith be able to program keys at that time?
Old Oct 10, 2017 | 11:46 AM
This is quite different than the original thread, so I moved it to it's own thread.
The immobilizer is in the PCM; what's located at the ignition key cylinder is the antenna to pick up the chip inside the key. You can check electrical connections from that antenna back to the PCM, and/or replace the antenna. I don't know how you'd figure out if the antenna is the problem, vs. the actual immobilizer component in the PCM.
Do you have any other keys on the same key ring? Any metal objects touching the key? Use your car key all by itself to see if that helps. (probably won't help but it's free & painless to try)
Old May 4, 2020 | 01:19 PM
Scott Nichols's Avatar
Default Same problem and looking for the solution
Hey so i saw here that you were having the same issues i am. Really interested in the outcome of your issues. Had locksmith out yesterday and he programmed the key, got it to start once, and then shut it off and couldn't get it going again. Wouldn't hold program.
Tiana 99 accord coupe
Sep 24, 2014 02:31 PM
Samzebian
DIY Answers.
Jan 31, 2011 09:56 PM
stevee1953
Jan 15, 2011 06:17 PM
Peter Lawrence
Dec 2, 2009 09:09 AM
choffman41
May 6, 2007 01:16 AM
