keyless entry problem
Old Jun 16, 2011 | 07:36 PM
mikejones305's Avatar
Default keyless entry problem
Hey guys, need some help.
The keyless entry only works on the passenger side when drivers side is unlocked. Other than that, it does not unlock doors once both are locked.
I was researching online and some people said it could be the actuator but if that was the case, would power lock work at all? because it does unlock using the button on the door. It just doesnt work using the remote.
Any suggestions?
Old Jun 16, 2011 | 08:15 PM
Give us your accord's info.
Old Jun 16, 2011 | 08:53 PM
2004, 2 door
Old Jun 16, 2011 | 09:01 PM
If the buttons in the car work, then the actuator sounds like it is working.
Do you have another remote to try just to rule out the one that you normally use?
Old Jun 17, 2011 | 07:43 AM
I made a mistake, the unlock button only unlocks passenger side, so it has to be the actuator. Thanks for your reply.
Old Oct 1, 2015 | 04:04 PM
Mahmoud Muhammed Selim's Avatar
When the locksmith programmed it a year back he used the above steps and worked for one day he didnt work on the receiver.
Can you please tell me where is the receiver to check on it?
I removed the battery till tomorrow to try refreshing the capacitors as I read smwhere..
I am sure of the frequency of the remote I have 433 mhz is for accird 2004 in middle east.
Old Oct 2, 2015 | 04:26 AM
Sadly the battery trick didnt work
Can sm1 tel me qhere is the receiver
KeystoneKid
Nov 5, 2010 01:15 PM
jimmy
Aug 2, 2009 10:36 AM
bryanboling
Oct 29, 2007 01:08 AM
IUHooshur
Jan 4, 2006 12:04 PM
93Miata
Nov 10, 2005 08:06 AM
