knocking noise on front left side of car when turning
Old May 16, 2010 | 12:02 AM
andrew404's Avatar
Default knocking noise on front left side of car when turning
whenever i turn, there is a loud knocking noise on the left front side of my 95 accord. any ideas on what this could be?
Old May 16, 2010 | 12:09 AM
Lightbulb Hi Member
Please...use the search engine here in the forum..that question has been answered
at leat 50 times in the last year..
A lot of questions can be found answered in the search forum above..
Please use it folks..saves you alot of time typing...
Attached Thumbnails knocking noise on front left side of car when turning-110109cu19cyou.jpg
Old May 16, 2010 | 09:15 AM
Wicked Pete's Avatar
I know this: CV joint, front wheel bearing assembly. Pretty common. I had to have mine done, I have a 95. The front bearing assembly/brake rotors don't just fall off, you have to have a slide hammer, impact tools. I took mine to a shop and $$$$. Usually "shadetree mechanics" will just pound them off with a big hammer. Not good.
Old May 16, 2010 | 01:31 PM
Just the CV joint.
Old May 16, 2010 | 02:31 PM
CV & axle seals!
Old May 16, 2010 | 07:01 PM
deserthonda's Avatar
DO NOT replace any parts till properly diagnosed, if it does turn out that you need a new axle , you DO NOT need to replace the axle seal unless it is leaking now ...
sounds like a bad outer cv joint to me ..
Old May 16, 2010 | 08:41 PM
kris_loehr's Avatar
Look at the joints and see which boot is torn and that is usually the bad one. I have not liked the aftermarket rebuilt axles I have installed. They always seem to be a pain to get to seat properly in the trans without work on the retaining clip or cleaning up the spline. At one time people would just replace the joint with a new one, but I think it was more money than a rebuilt axle. I also remember some of Honda’s axle doesn’t come apart to easy or at all. Let us know what you find.
badb0ybilly
Jan 21, 2014 06:54 AM
Fredcheesemonkey
Mar 27, 2013 01:15 PM
samboka27
Aug 17, 2010 12:02 PM
mbnjagn
Mar 13, 2008 03:20 AM
FlyLow
May 8, 2006 06:00 AM
