Leak on engine side of exhaust near cat converter
Old Jun 29, 2011 | 05:04 PM
kturnerga's Avatar
Default Leak on engine side of exhaust near cat converter
Hello
I still have that old 92 Accord. It has a buzzing sound coming from the exhaust and I smoke-tested it via plugging the exhaust. It seems to be from the engine side near the joint with the cat converter. Should I yank all of the exhaust, cat converter and all, and replace it myself? Or is it a job for the muffler shop?
BTW I hear there are two O2 sensors on the exhaust system that, when disconnected and reconnected, give a check-engine light and mess up your gas mileage. Is that true?
Thanks
KT
Old Jun 29, 2011 | 05:12 PM
Your 92 accord only has one O2 sensor. It is either on the exhaust manifold or on the pipe right before the catalytic converter. The 96+ accords had two O2 sensors for OBD2.
If the leak is coming from a gasket, then have the gasket replaced. The exhaust bolts may be very rusty, so take a look before attempting to take apart. You can always get a quote from a shop to see what they would charge to install.
Your car is OBD-I, so you only have one O2 sensor.
Regarding the exhaust, you can DIY or go to a muffler shop. If you DIY, sometimes the bolts can very tough to get loose and bolt heads may break off.
dragonwyatt
Jan 6, 2014 08:04 PM
alltime3rdwheel
Dec 31, 2012 10:46 AM
tlhfirelion
Oct 10, 2010 03:04 PM
v-tec23
Aug 14, 2010 08:43 AM
hellomoto
May 6, 2006 12:09 PM
