Left fog light blew out every 2 days
Old Sep 26, 2009 | 04:24 PM
Nolimit167's Avatar
Default Left fog light blew out every 2 days
Honda Accord Sedan 07
Recently, my LEFT fog light has stopped working. I have a 6k HID kit h11 bulb for my fogs. I have no idea why it stopped working all of a sudden. When I first installed the hid kit for my fogs, it worked really well for a good 3 weeks but now, the left fog decided to stop working, the right one still works. Furthermore, my cigarette charger stopped charging too. So yesterday, unhappy with the unfortunate events that happened with my accord, I decided to check out why my cigarette charger stopped working. After 30 minutes of research, I learned that the fuse might be responsible for this. So, I looked for the cigarette lighter fuse which is called (FRONT ACCESSORY) and what do you know....it was blown. I replaced the fuse and it works again....and guess what???? my left fog light started working again too!!!! THEN after a day, it stopped working. I checked the fuse once more and you guessed it, it was blown!!! (only after a day!) . I'm thinking that the left fog light and my cigarette lighter wires are connected? I don't know. Please help. The fuse for the cigarette lighter is 15a. I also checked the fuse for my fog lights, it's fine.
Old Sep 26, 2009 | 05:31 PM
You will have to find a wiring diagram for your car, because there are probably many items on that circuit. You might want to take out the fuse for the fog lights to remove them from the circuit. See if using the cigarette lighter or anything else electrical blows the fuse.
Its weird that only one fog light will turn off when the fuse blows. Were the fog lights installed at the factory, or are they aftermarket?
Old Sep 26, 2009 | 05:59 PM
Nolimit167's Avatar
it was factory =/ ....sigh....i want to take it to the dealership but seeing that I installed HID...iono if they will fix it ....
Old Sep 26, 2009 | 07:48 PM
o CRA5H o's Avatar
ok i know this is going to sound wierd but look in the bottom of the cigarette lighter and see if there is a penny or some other coin in the bottom of it. if there is its shorting out everything on that circuit. if there isnt then u probably have a wire somewhere near the ballast that has rubbed raw and grounding out......but u might want to have the ballast checked out anyway. just a thought
pokiri_pandu100
Apr 9, 2010 03:27 PM
kris_loehr
Dec 18, 2008 06:03 PM
stowngo
Aug 29, 2008 12:34 AM
Briggz
Sep 18, 2007 05:27 PM
t00fatt
Feb 24, 2007 02:55 PM
