Location of hazard/turn signal relay
Old Dec 6, 2007 | 01:21 PM
deserthonda's Avatar
Default RE: Location of hazard/turn signal relay
is there power at the green/red ?? the way you are describing it , sounds like you do have a bad turn signal switch
Old Dec 6, 2007 | 07:05 PM
HondatechAV6's Avatar
ORIGINAL: deserthonda
x2
Old Dec 6, 2007 | 07:11 PM
The Grn/Wht wire is the power input to the flasher relay. When you jumped Grn/Wht to the Grn/Blu or Grn/Yel, you bypassed the flasher relay. Jumper the Grn/Red wire (relay output) to Grn/Blue or Grn/Yel and the flasher will work w/ the turn light.
If this works, the turn signal switch is the problem.
Old Dec 7, 2007 | 12:35 AM
ORIGINAL: TexasHonda
that is why i asked him to chk for power at the green./red wire .. if there is no power but there is power at green/white , it has a bad relay ,,at least ,,
If it has power at green/red ( after the realy ,also power input to the turn signal switch) ,than relay is good ,,, than it is a bad turn signal switch .
Old Dec 7, 2007 | 09:18 PM
dfeat01's Avatar
Well what a freaken long day of cleaning up on this car. So I took my multimeter and placed it across the grn/red wire on the turn signal and I get 12V. If that answers your question desert honda. Im really starting to think its the switch problem because im getting the 12V into the switch according to the multimeter. Is this what you were talking about?
Old Dec 7, 2007 | 09:20 PM
yeah, that was exactly what he was talking about. since you jumped power to each individual terminal from the switch in the previous post, you confirmed the switch is bad.
Old Dec 7, 2007 | 09:43 PM
  #17
dfeat01's Avatar
Kool. Thanks for the help guys im going to order that switch tomorrow. Ill let you guys know the result. [sm=signs003.gif]
Old Dec 10, 2007 | 02:49 PM
  #18
dfeat01's Avatar
Now this is going to sound weird. I decided to put back the center console (plastic trim around the radio, ac unit, clock) and guess what? My turn signals starting working again! I didn't have to order a new switch or nothing. But now my clock doesnt light up. Oh well I can deal with that. Its a little annoying knowing it wont light up but turn signals are more important. Thanks for the help guys.[8D]
Novaknowledgenow
Jan 16, 2015 07:21 PM
Floyd Yap Singson
May 16, 2013 10:16 PM
PeterFlorida
Feb 26, 2013 09:09 AM
jdmzach
Jan 8, 2013 08:46 PM
Drake75
Mar 24, 2012 12:34 PM
