Loosing air pressure in just one tire
Old Jan 30, 2011 | 06:23 PM
NJ007's Avatar
Default Loosing air pressure in just one tire
Hi
I am having a strange problem. Me loosing air pressure in my front left tire... it goes down from 33 34 to near 23 within days.. can n e one suggest n e thing?
Thanks
Old Jan 30, 2011 | 07:11 PM
Probably a nail or hole in the tire. Do you want to repair the tire? Most tire places will plug the tire and its not too expensive.
Old Jan 30, 2011 | 10:18 PM
whitetailkiller-2008's Avatar
not really strange???? happens ever day..take tire off the honda...bring to a tire shop... or just drive it there they will fix it..could be a bad valve stem or just a hole in tire from a foreign object. or u could try and do it urself with a plug... spray water on tire to find the hole.. and plug it up
Old Jan 30, 2011 | 11:10 PM
Originally Posted by NJ007
Hi
Thanks
Do you have TPMS on this car..it doesn't say what it even is...
Old Jan 31, 2011 | 11:50 AM
Spray some soapy water over the tire & watch for bubbles.
Nail or something in the tread? Probably fixable.
Leak in the sidewall? Probably not fixable.
Valve stem? Fixable.
Corrosion around the bead? Maybe can be re-sealed??
Old Feb 5, 2011 | 03:03 PM
NJ007's Avatar
Thanks
Old Feb 6, 2011 | 12:27 AM
EXV6NIGHTHAWK's Avatar
Yes, use some dishwashing liquid and water. Take the wheel off, and use a brush to cover the entire tire/wheel/valve stem with sudsy water. The growing bubbles will show the leak. At work we test 35ft long- 6ft X 6ft pontoons this way with only 2 lbs of air pressure. I have fixed/pluged my own tires at least 50 times this way, and it always works. Michelin tires that have come with both my Accords seem to be nail magnets.
Old Feb 6, 2011 | 01:14 AM
Wheels get moisture in the winter and they corrode..have the tire shop break down the wheel and sand and clean that rim..then re-air it up and see if that don't fix that problem...
dornbla9
May 18, 2012 09:53 PM
bustum
Apr 11, 2012 02:10 PM
Miamijuan
Aug 23, 2011 03:36 PM
1accord1996
Apr 7, 2011 12:36 PM
Mikkos
Feb 26, 2010 03:19 PM
