loud droning noise problem
Old Apr 24, 2012 | 08:45 AM
ccamp's Avatar
Default loud droning noise problem
My accord suddenly started having a loud droning noise while I am driving (not when stopped.) It sounds like an airplane is flying overhead. Can you help?
Old Apr 24, 2012 | 05:44 PM
This may or may not be the right place for this, lets see where it goes. I might have to move it to General Tech.
Does the noise "seem" to be related to the speed of the car in anyway? Or is it related to the engine rpm's more than speed?
Old Apr 25, 2012 | 11:26 AM
ccamp's Avatar
Thanks..it does get louder when i go faster
Old May 16, 2012 | 10:13 PM
nyc2sd30's Avatar
It could be a number of things. First thing that comes to mind when I hear the word droning is the tranny, but it could be something as simple as an uninflected tire.
Old May 18, 2012 | 07:38 AM
bluoval's Avatar
Could be a bad wheel bearing. My left rear went bad and sounded like you describe. I got away with driving it for a week or so, but you don't want to push your luck. It seems to gradually get louder as the days go by, and also as you pick up speed. You can usually tell if the noise is coming from the back or front, but to isolate to the correct wheel hub can be tough unless a mechanic has it on a lift and can test them.
Old May 20, 2012 | 10:33 AM
This should have been posted in the general tech help section.
I agree it may be a bad wheel bearing. On my 8th generation Accord, it was a bad front wheel bearing that was causing a droning noise. It was coming from the front; but, was difficult to determine which side. Even when I had car on a lift, me and my mechanic friend couldn't really tell which side it was. The traditional methods of trying to move the wheel back and forth, spinning it, etc. didn't really reveal which side. I drove it a while longer and guess correctly which side it was (I heard it more distinctly driving very late at night when there wasn't much environmental noise).
The wheel bearing unit actually has like two inside the unit; so, many times the car can really be driven for quite a while with the occasional noise before it gets progressively worst (e.g., gets louder, vibrations, etc.).
Old May 21, 2012 | 05:32 PM
Yea, I should have moved it to begin with
sjm5104
Jul 3, 2009 05:27 AM
grits
Feb 25, 2008 11:01 AM
kornfox
Dec 13, 2007 07:17 PM
Amiinfocusatwork
Jan 18, 2007 05:27 PM
96hondaaccord
Aug 11, 2006 01:36 PM
