Loud Engine Noise
Old Mar 29, 2007 | 03:30 PM
kornfox's Avatar
Default Loud Engine Noise
I have a 1997 Honda Accord LX and have noticed the engine is much louder than other hondas with the same engine/mileage. Under even normal accelleration the motor seems to be rather loud. I do not have any problems with my exhaust (holes, leaks, etc) but I do have an aftermarket intake. I know non-stock intakes will create some more noise under the hood, but this isnt the sound of air suction, just loud noise. Even idling seems louder. Is this normal for a 146k motor? Anything I can do?
Old Mar 29, 2007 | 04:49 PM
sir_nasty's Avatar
Default RE: Loud Engine Noise
depending on what the noise sounds like means what it may be... aftermarket intakes usually provide a deep sound similar to an exhaust (that's the best way I can describe it...) if it sounds kind of tinny or like a tink tink type sound then an oil change, distributor cap, rotor, spark plugs (Ngk), wires, fuel injector cleaner and maybe even a valave adjustment (if it hasn't been done recently) will greatly reduce the amount of engine noise that you hear, for squealing sounds that's usually a belt of some sort
Old Mar 29, 2007 | 05:14 PM
kornfox's Avatar
great. im having the valves adjusted this within the week. thank you!
Old Mar 29, 2007 | 05:20 PM
sir_nasty's Avatar
there is also a really nice full write-up in our DIY section for the valve adjustment if you want to tackle it on your own....
Old Mar 29, 2007 | 05:23 PM
kornfox's Avatar
Yeah, I saw that. Looks terrifying.
Actually, it doesnt look that bad, but ive never done 'internal' engine work and am afraid i might make something worse than it is..
Old Mar 29, 2007 | 05:43 PM
sir_nasty's Avatar
With the go/no-go guages it's pretty easy actually but I can understand your concern, I wasn't to fond of doing internal work to start with and since it's a pretty easy job a mechanic shouldn't charge more than like an hour + the gasket so it won't be that expensive.... if it was a timing belt on the other hand then I'd suggest tackling that one....
Old Dec 13, 2007 | 05:31 PM
HondaPhyco's Avatar
Just an idea....for the newbs like me why dont you guys make tutorials not for all years but for like 95-98 (videos)
Old Dec 13, 2007 | 07:17 PM
finch13's Avatar
Because we are regular people who have lives outside of this forum. The engines vary so much by model that we just don't have the time. We offer advice and even if we did have tutorials we can't provide you with mechanical skill. If you feel you can't perform the task then leave it up to a mechanic to do. Not trying to flame you.
faran
Dec 18, 2013 08:13 PM
lotas
May 8, 2012 08:50 PM
brucehjr
Apr 18, 2010 07:01 PM
Amiinfocusatwork
Jan 18, 2007 05:27 PM
96hondaaccord
Aug 11, 2006 01:36 PM
