main relay or fuel pump?
Old Jan 23, 2008 | 09:36 PM
fastdart360
Default main relay or fuel pump?
is thier a difference between a fuel pump relay and a main relay on a 1998 accord ex v6 the car wont start, and where is the relays at? i would say under the dash?
Old Jan 24, 2008 | 07:52 AM
Default RE: main relay or fuel pump?
Under the dash, driver's side.
Turn the key to 'ON' but don't immediately continue to 'START'. Listen for the fuel pump to run about 2 seconds & then quit.(The fuel pump isn't very loud, soturn off the music & fans.) If the relay clicks on & off, the sound will help you find it. If the pump doesn't run, that would indicate a bad main relay or a bad pump.
Main relay & fuelpump relay are the same thing, sorta...
The 'PGM-FI Main Relay' for the fuel injection system is really 2 relays built together inthe same little housing. One of these is the fuel pump relay. The other switches power to the ECU, injectors, several sensors, etc...
Malcontent
Jun 29, 2015 12:46 AM
crazylegs12
Oct 15, 2011 07:48 AM
uraceulose
Oct 2, 2009 11:45 PM
greg05
Aug 31, 2009 05:32 PM
kissbally78
Jan 18, 2009 07:14 PM
