Main relay signs/symptoms?
Old Jun 24, 2006 | 06:44 PM
jrcastro's Avatar
Default Main relay signs/symptoms?
What are the signs & symptoms of the main relay issue on a 92 accords?
I start my car gas & fuel get in fine then all of the sudded it dies, try it again then it will not start.
What else could it be?
I wait a few minutes it works fine. this only happens occasionaly.
Old Jun 24, 2006 | 06:59 PM
Chiovnidca's Avatar
Default RE: Main relay signs/symptoms?
ORIGINAL: jrcastro
Sounds like it. they usually act up more when it is hot out. Checking it for cracked solder joints is a good diagnostic procedure.
Old Jun 24, 2006 | 08:03 PM
mbo1985's Avatar
yeah, sounds like the main relay could be giving you a problem. As Chiovnidca said, look for cracked or dull looking solder joints if you decide to check it out.
Old Jun 24, 2006 | 11:28 PM
deserthonda's Avatar
if you go to the DIY section, there is a link to a write up on main relay
Old Jun 26, 2006 | 01:20 PM
jrcastro's Avatar
When driving the car all of a sudden it died (only happened once) tried to restart no luck. waited a few minutes started fine.
Is this also one of the signs/symptoms?
I thought the relay problems are only upon start up?
Could it be something else?
NOTE: Probable main relay problems started acting up on a normal 85degree day in Ca. is this hot enough to make the relay malfunction?
Old Jun 26, 2006 | 09:20 PM
Chiovnidca's Avatar
ORIGINAL: jrcastro
A main relay very rarely causes a stalling problem like that. Next ime it happens, see if it has spark.
mamtsberg
May 27, 2013 01:55 PM
HondaPete14
Feb 15, 2012 05:34 PM
greg05
Aug 31, 2009 05:32 PM
jrcastro
Apr 21, 2008 10:35 AM
HondaAccordNewb
Jan 16, 2008 06:08 PM
