maintenence required light
Old Mar 17, 2006 | 01:36 PM
sir_nasty's Avatar
Default maintenence required light
I read some of the older posts but I just wanted to confirm that I was looking at the same thing... I have a little green "light" (doesn't really look like a light but more of an indicator) that is green on my speedo just under the odom. It's green right now and says "maintenece required" is this the indicator that other people have referred to that goes off after 7.5k miles? and how do I reset it? I read to hold the reset switch in and put in the key and wait about 15 seconds but I wasn't sure...
Old Mar 17, 2006 | 03:02 PM
marbro's Avatar
Default RE: maintenence required light
Yup, that would be it, tho im not sure about it being green, but maybe its just different with your year of accord
Old Mar 17, 2006 | 03:07 PM
lightshow's Avatar
yep that just means you need a oil change...nothings wrong with your car....as many times as ive seen how to reset it....i cant remember.....hopefully desert or someone that knows how will pop in today
Old Mar 17, 2006 | 03:11 PM
sir_nasty's Avatar
It's a replacement Speedo.. I have the old one in the back of my car *L* The person I bought this car from has Literally a FULL glovebox of Maintence records... Speedo changed (apparently a common issue) Timing belt, regular oil/services... I couldn't believe it...
Old Mar 17, 2006 | 04:23 PM
deserthonda's Avatar
that lite changes from green to yellow to red,, when it is red , it is due for maintanance,, what you do is stick the ignition key in the little slot right next to the maintanance lite and push down on it ,, it will reset the lite to green...............if it is green now you are ok,,, that lite is supposed to change color as you approach 7.5 k milers telling you that it is due for service,
You must have an earlier year car....
...next time you ask a question , it would be nice if you could start with year and model we are dealing with, it makes it much easier for all of us who are trying to help you..
Old Mar 17, 2006 | 04:30 PM
sir_nasty's Avatar
Okay that makes sense.... I know what slot you're talking about.... sorry on the year/model thing... it's a 94 ex... but it's a replacement speedo... Thanks for the info though!
bpdunlv
Jul 15, 2009 05:00 PM
erdie721
Jul 18, 2007 09:14 AM
jipmpizzle
Apr 20, 2007 08:51 AM
wayneboard2
Dec 18, 2006 07:24 PM
demoniam
Sep 22, 2006 01:23 PM
