Malfunction Indicator/O2 Sensor/Cruise Control
Old May 26, 2015 | 09:39 AM
svhonda's Avatar
Default Malfunction Indicator/O2 Sensor/Cruise Control
Yesterday my Malfunction Indiciator came on and I understand that may indicate my O2 sensor is bad (most likely at the catalytic convertor); however, this morning I noticed my cruise control does not work. So is it possible that the cruise is not working because of the O2 sensor? Or is this maybe something different?
I want to avoid replacing the wrong thing. I haven't gone to have a code check yet as this is the first day after a holiday.
Thanks
Old May 26, 2015 | 11:49 AM
Start by telling forum what Accord you are driving, year and trim level.
If car is equipped w/ OBD2, then go to Autozone and ask them to scan for codes, write down the codes (Pnnnn), and post them.
Old May 26, 2015 | 07:13 PM
svhonda's Avatar
2006 Honda Accord EX 4cyl
I will get the code scan. Thanks!
Old May 27, 2015 | 11:36 AM
svhonda's Avatar
Ok, got the scan.
P0139 (Secondary H02S12 (heated oxygen sensor - bank 1 sensor 2) circuit slow response.
Would this also affect whether the cruise control works or not as stated in my original post?
Thanks!
Old May 29, 2015 | 09:50 AM
This would not affect speed control and won't affect drivability, however car will not pass an emissions test. Problem could be a faulty sensor, wiring or connector fault, or less likely a faulty PCM.
Alien VFR
Sep 11, 2010 02:02 PM
Jeff247
Jun 3, 2008 06:13 AM
pham9006
Mar 22, 2008 12:04 AM
blahblah
Mar 18, 2007 02:33 PM
djsinister
Mar 1, 2006 03:11 AM
