misfires - NO check engine light
Old Mar 9, 2009 | 05:04 PM
rwarrer
Default misfires - NO check engine light
hi,
misfires even at low speeds - NO check engine light!
new plugs, wires, cap, rotor, ignition coil. honda adjusted timing and valves.
still misses after 2 miles of driving????
bad distributor?
bad ignition module?
Old Mar 10, 2009 | 06:42 AM
Welcome new member!
I'm gonna move this to the technical area since this new-member area is really only for introductions & saying HI...
What kind of spark plugs did you buy?
Old Mar 10, 2009 | 09:31 PM
Demonrunner's Avatar
Try a new fuel filter and running some dry gas or something to remove possible water contamination in your tank
Old Mar 11, 2009 | 01:22 AM
Gbav1's Avatar
I had the same problem, put a new set of plug wires, still had the problem, got to looking at the wires really good, and found that one of the wires was going to ground inside the head, below the boot, so you couldn't see it when the engine was running.
The were brand new wires from auto zone.
Old Mar 12, 2009 | 11:19 AM
rwarrer
Originally Posted by JimBlake
Welcome new member!
sorry and thank you
rwarrer
Old Mar 12, 2009 | 11:31 AM
rwarrer
thanx,
good suggestion - i'll do a good visual inspection. the only ignition component i haven't replaced is the ignition module - your thoughts?
rwarrer
Jay Martin
Sep 4, 2013 08:50 PM
hess1809
Mar 1, 2011 12:10 AM
2001SCAccord
Sep 10, 2010 04:15 PM
Hondaccord
Jul 26, 2008 11:53 AM
