need help with 92 accord trans
Old Apr 13, 2013 | 09:28 AM
  #21
biker9's Avatar
If the D4 light in the gauge never comes on....pull the gauge and check the bulb.
OK, thought that would be next, just wanted to be sure before pulling it. Will post what I find, thanks for the confirmation.
Old Apr 20, 2013 | 02:54 PM
  #22
biker9's Avatar
I pulled the instrument cluster and all the drive indicator bulbs look visually OK and all show continuity across the connector pins. The back of the instrument panel circuit board though is damaged (signs of scorching and flaking) on the lower left (looking from the back, lower right looking from the front). Any ideas where I can get a new instrument cluster? ebay?
just checked ebay, several instrument clusters on there, will any of the 1992 clusters work or do I need to find one specific to my model? I have the 2 door model.
Old Apr 20, 2013 | 03:06 PM
  #23
Ebay is one source. Craigslist possibly for part outs. Honda forums as well.
A u-pull-it junkyard. Or go to car-part.com and search junkyards that subscribe to this site. You can sort by price or distance to see what is in your area.
Old May 14, 2013 | 09:05 PM
  #24
biker9's Avatar
OK, I finally got a used cluster, installed it and the D4 now works. Waiting for a repeat of the limp mode condition so I can retrieve the code. Again, thanks for the help!
Old May 15, 2013 | 04:35 PM
  #25
biker9's Avatar
Last night after installation of a used instrument cluster and reconnection of the battery the car drove fine. Upon cold start today it was in limp mode and the D4 indicator light stays on in all gears. The check engine light did not come on until I shut the engine off and back on. However, it did not stay on after a couple more times of turning it off and on the check engine light is no longer on.
I jumped the connector to get the codes but neither the D4 indicator or check engine light would flash. Any ideas???
Old May 17, 2013 | 05:23 PM
  #26
biker9's Avatar
After multiple attempts I do not get a code. Check engine light and D4 are illuminated, I guess that means code "0" which it appears indicates a problem with the ECM.
I believe the TCU in my car is good because: 1)when the codes are cleared the transmission works flawlessly, 2) the TCU was replaced a few years ago and 3) visual inspection of the TCU shows no leaking capacitors or burned resistors.
Guess I need to get an ECM, I have looked inside the ECM and it looks fine.
Is there anything else I should check before getting an ECM?
Also, any recommendations for a rebuilder or supplier of an ECM?
Old Aug 19, 2013 | 08:36 PM
  #27
biker9's Avatar
to close this one out, it was the ECM. picked one up from a salvage yard and all is well.
BSims66173
Apr 14, 2013 06:11 PM
bsd983
Mar 6, 2012 02:32 PM
habbababba
Aug 22, 2011 11:32 PM
Durney
Jun 5, 2008 06:50 AM
mgarcia85
Jun 3, 2007 11:49 PM
