Need help basic keyless alarm install
Old Nov 12, 2013 | 02:33 PM
HONDAACCORDG's Avatar
Default Need help basic keyless alarm install
New here, i have a 96 accord, i installed a basic keyless alarm, but when i arm it, then try to open the door like if someone was breaking into it, the alarm doesnt go off, it goes off when i close the door. Does anyone have any info, like maybe i tapped the wrong wire, i didnt understand the negative and positive wires from the alarm, and does someone know which wire i can tap into, the location of it/ color/ how many pins in connector...thanks
Old Nov 12, 2013 | 02:43 PM
It would help if you listed the brand of the alarm, post the installation instructions diagram, and describe what wires you tapped into.
Bascially, your car's system is negative trigger; so, you would follow the instructions for a negative trigger system.
See this thread:
https://www.hondaaccordforum.com/for...on-help-56065/
Old Nov 12, 2013 | 03:27 PM
http://www.bulldogsecurity.com/image...nual013105.pdf
THIS IS THE LINK, IM NOT USING THE RELAY( NOT SURE IF I HAVE TO, I HAVE A KILL SWITCH INSTALLED) THIS IS MY FIRST ALARM INSTALL, I TAPPED INTO THE SECURITY 3PIN CONNECTOR, THERE WAS A SIDEWINDER ALARM PREVIOUSLY INSTALLED, I KIND OF WENT OFF THOSE WIRE THEY TAPPED INTO...I GOT IT WORKING, IT WOULD ARM AND DISARM/LOCK AND UNLOCK DOORS, MY MAIN CONCERN WAS GETTING IT TO SOUND WHEN OPENING THE DOOR...THANKS FOR THE HELP
Old Nov 12, 2013 | 06:51 PM
Please don't type in all CAPS, it means you're yelling.
For your alarm, you would connect the H8/4 Green Wire - Negative Door Switch Sensing input (page 9 of instructions) to your Accord "Door Open Input" Blk/White wire. The Door Open Input Blk/Wht wire is located behind the left side of the driver's kick panel area at the Grey 20-P connector (Connector C435). It is pin 5 on connector C435.
Connector C435
Old Nov 13, 2013 | 10:02 AM
sorry used to all caps...i figured it out last night, i had that green wire h8/4 connected first, then i hooked up the other negative blue/white wire h8/2, and got it to work properly...thanks for the help...
minchina
Sep 8, 2012 08:18 PM
phatboyslim2012
Jan 24, 2012 06:11 PM
yutaka731
Feb 12, 2011 03:41 PM
rmb34
Dec 15, 2009 11:16 AM
stanley.ysf
Aug 23, 2007 07:42 PM
