need help diagnosing radiator fan not running
Old Aug 24, 2014 | 04:33 PM
moey's Avatar
Default need help diagnosing radiator fan not running
2007 Accord I4 automatic
I finally completed putting in my transmission. And low and behold when I go to test it out I notice the radiator fans not coming on. Engine got about 3/4 of the way up the temp gauge. The radiator fans do run if you put the A/C on but do not come on with them off.
Is this most likely the sensor on the bottom of the radiator?
I replaced the radiator when I did the transmission but I was extremely careful removing the old sensor. It is possible the old sensor was not working before I have not driven the car that much to know and probably had the A/C on.
Old Aug 24, 2014 | 05:24 PM
If both fans run with the A/C on; then, yes, it can be the ECT sensor at the bottom of the radiator or the ECT wiring or connector. Examine the terminals on the connector and wiring. The ECM/PCM uses input from the ECT sensor to control the fans.
Old Aug 29, 2014 | 08:03 AM
moey's Avatar
Seems to be working now. I was considerably low on antifreeze and had air in the system. I think that may have caused the sensor to act wonky..
Novaknowledgenow
May 30, 2013 08:58 PM
rtmobile96
Sep 16, 2007 04:14 PM
webvan
Sep 3, 2007 07:12 PM
ksorbo
May 24, 2007 11:20 PM
MitchA
Mar 17, 2006 03:47 AM
