94 Accord Radiator Fan Running
Old Mar 16, 2006 | 09:28 PM
MitchA
Default 94 Accord Radiator Fan Running
Radiator Fan runs continuously until car is started or battery cable is removed. If I start the car and then turn if off the radiator fan comes on (Even after 5-10 seconds while the engine is cold. The fan is not even running while the car is running). If I turn the key back to an "on" position (to where the radio comes on) the fan stops. But when I turn the ignition back and remove the key the fan comes back on. If I disconnect the battery cable for about 5 seconds and reconnect then it stops and doesn't restart. The thermostat is brand new and there are a couple of relays/switches that I guess could be involved. I'm a little stumped and don't wanna pay honda service for something simple. I waited as much as 25 minutes the other day and the fan was still running.
Any help is greatly appreciated. I'm not real good at this, so I would need a good guess as to what part is bad and help with locating the sensor/switch/whatever it may be under the hood.
Old Mar 16, 2006 | 09:52 PM
lightshow's Avatar
Default RE: 94 Accord Radiator Fan Running
your fan timer should run the fan if the temp exceeds 223 degrees for about 15 minutes. if it running longer than that, your fan timer might be bad, the relay might be bad, or there might be a faulty connection somewhere.
Old Mar 16, 2006 | 11:14 PM
MitchA
Coolant temp sensor replaced per suggestion from another forum. Didn't help. Relay is fine. Same relay as power windows. Swapped out and no change. Any other obvious quick replacement parts to check?
Old Mar 17, 2006 | 03:36 AM
lightshow's Avatar
fan timer.....sounds like you have boiled it down to that
Old Mar 17, 2006 | 03:47 AM
lightshow's Avatar
and why dont you take a look at this. courtesy of our resident general maintenance guru deserthonda
accord cooling system diagnosis
Novaknowledgenow
May 30, 2013 08:58 PM
quintas
Jun 30, 2012 11:12 AM
esobofh
Aug 19, 2009 12:48 PM
webvan
Sep 3, 2007 07:12 PM
ksorbo
May 24, 2007 11:20 PM
