Need help with fuses
Old Feb 22, 2007 | 08:58 PM
bustum's Avatar
Default Need help with fuses
Is there a fuse or relay associated with the temp gauge, and if so, which one is it and where is it located? Also, can any one lead me to a link that explains how to remove and replace the temp gauge in a 94-97 Accord?
Old Feb 22, 2007 | 09:15 PM
sir_nasty's Avatar
Default RE: Need help with fuses
here's the basic instructions for removing the paneling to get to the guages, from there it should be fairly straight forward... and I don't know of any fuse that is specific to that guage... if there were a fuse out it should affect more than just the temp guage, but fuse #1 may...
[IMG]local://upfiles/3079/9661D13A3AD24C02AD5D361A8008034F.jpg[/IMG]
[IMG]local://upfiles/3079/149E9CA8B0684923A122573B04E31801.jpg[/IMG]
Old Feb 22, 2007 | 09:17 PM
Fuse No 1 (10A) in the under-dash fuse box supplies the ECT, and all other gauges of the IP. It's the 2nd from left of bottom row. First fuse is slightly lower and a spare as is the last 5th fuse on RH side of lower row.
I would suggest downloading or purchasing a manual. This is far and away best info for repair.
Old Feb 22, 2007 | 09:23 PM
sir_nasty's Avatar
speaking of manual's here's a link.... you want the one I gave you the info from? it's free
http://hondatech.info/downloads/Auto/Manuals/Accord/
Old Feb 22, 2007 | 09:40 PM
bustum's Avatar
Thanks guys. One more question: Do you know if the temp gauge out of a 97 Accord SE will work in my 94 Accord EX? I checked on the net and it seems that the SE has an F22B2 engine and mine is an F22B1. I'm thinking it shouldn't make a difference with something like the temp gauge, but I am not really sure. I just got a great deal on the entire instrument cluster out of a 97 SE and hope the temp gauge out of it will work in mine. BTW, if I was to put the whole gauge pod in, how do peolple deal with the difference in mileage when they put used pods out of other cars?
Old Feb 22, 2007 | 09:47 PM
sir_nasty's Avatar
the whole guage pod thing depends on your local state laws, I bought my car with a replacement odometer (you do have to/want to disclose that information if you ever sell it) and since it was over 9 years old it wasn't required that the mileage be recorded for title work etc. So in MT it makes no difference, the only issue I can see with using a 97 SE cluster is your dummy lights, if the lights/layout/connections are all the same it should be fine, if not I'd just swap the guages, I'm pretty sure those are the same
Old Feb 22, 2007 | 11:46 PM
One way to check if they are the same is to check the parts on http://www.hondaautomotiveparts.com/ for both models. Compatible parts will definitely have the same part number. Different part numbers might be compatible, but there is no guarantee.
Old Feb 23, 2007 | 12:35 AM
bustum's Avatar
I've seen this setup for selecting parts on a couple other sites, but I can't figure which part is the temp gauge. I select "instrument panel" and it leads to a black and white diagram of the interior, but I don't know what's what. Can someone help me as to which choice on the drop down list and which part number corresponds to the temp gauge?
Old Feb 23, 2007 | 12:20 PM
I've had good luck w/ checking interchange-abilty w/ car-part.com's search engine. It will list all the potential salvage donor vehicles in the US (usually quite a large number), and there's a large enough database to insure virtually every possible model match is covered.
Old Feb 23, 2007 | 02:32 PM
sir_nasty's Avatar
I ran into the same issue.... I couldn't find it on that drop down style either...
ORIGINAL: bustum
Nickolas Conwell Shaffer
Jan 1, 2013 11:19 PM
dupydog
Feb 12, 2008 03:14 AM
Cun0144
Sep 30, 2007 08:33 PM
laststop711
Apr 19, 2007 05:25 AM
Hondabeater
Jun 14, 2006 10:10 PM
