need help with my 2000 honda accord
First thing you need to do is get the codes, they will be stored in the PCM. Many parts stores will do this for free, you need to get the actual code from them (P and four digits) and not their description of the issue.
My guess would be the electrical portion of the ignition switch is causing the issue. An easy way to test this is to start the car and let idle. then slightly tap the key backwards quickly but don't turn the engine off. if the vehicle stalls then that would indicate a worn out ignition switch ( electrical portion.) it is very common to your model accord.
Let me know if this helps.
pats
pats
b|@ck-0n-b|@ck
Aug 14, 2010 08:48 AM
