Need Help! P0-341 Code Camshaft Postion Sensor A Bank 1-2003 Honda Accord
Old Feb 26, 2015 | 10:06 AM
  #31
hipramodbhu's Avatar
The timing chain issue caused the bent valve(s). They would have not known the valve was bent until they could get the timing back in correct order. So don't blame the shop for the bent valve(s)....that was caused by not taking care of the timing chain when it should have been.
Is the starter spinning the engine or when you try to start it the starter does nothing.
When morning I started I got one - two times click and click and after that I did not make any sound. I put anothetr battery in parallel but could not start. Its not trying to do start at all. I reported to dealer after getting my car that I have to hold my key for little longer tiem start. Also, When I measure RPM through scanner then I was getting 650 rpm in idle state. I told these problem to dealer. He said these problem are ok. Just drive for few weeks then your car will run fine. But now next day again not starting.
Old Feb 26, 2015 | 11:16 AM
  #32
Make sure battery cables are clean and tight. They may have removed battery cables to do this repair and failed to tighten securely.
Old Feb 26, 2015 | 11:31 AM
  #33
I checked that connection. Looks good. I spoke to dealer he said that it might be starter now. I am surpised one by one these problem.
Old Feb 27, 2015 | 11:25 AM
  #34
I read somewhere if timing chain is not installed correctly then car not start as normal start. Is this true? Now, Dealer is replacing starter motor and charging $500. I am really got fed up. Can anybody help me?
Old Feb 27, 2015 | 12:21 PM
  #35
Clicking sound can be starter fault, low voltage (bad battery), damaged battery cables.
Chain and tensioner replacement should not have affected starting system IMO.
Old Feb 27, 2015 | 07:30 PM
  #36
Do you have any codes? Yes if the timing chain was not set properly the car will not start BUT YOU SHOULD know that you would also be getting a P0341 code. So if you have no codes don't try to blame the timing chain "work".
bossie
Mar 29, 2021 11:17 PM
3dw1n
Jan 14, 2015 01:53 AM
choi
Apr 18, 2014 08:43 PM
sparkyg
Jul 12, 2006 09:41 PM
