Need help with P0171
Old Dec 15, 2013 | 08:33 AM
gr4v3y4rd's Avatar
Default Need help with P0171
Hi all, I'm a new member here. Been getting P0171 for the past month is on and off everytime i erased it. So far I've already change fuel pump and regulator, injector, EGR valve and O2 senso bank 1. I check the vacuum leak, nothing. The code just comes out again today, scractching my head off, Need help and any advise.BTW my car is honda accord 04 2.4 sulev.Thanks guys
Old Dec 15, 2013 | 09:08 AM
The P0171 can just be the Mass Air Flow (MAF) sensor being dirty. Check the condition of the air filter and gasket. Then use some MAF sensor cleaner spray (CRC makes it) on the sensor.
https://www.hondaaccordforum.com/for...iat-sensor-jpg
Old Dec 15, 2013 | 03:16 PM
Are you just getting the one code PO171 or maybe getting another code along with it..(ie) PO172.. ?
Check to see if there is a 2nd code in there..
Old Dec 15, 2013 | 09:16 PM
jafriede's Avatar
I'm sure it's not this simple, but I had the exact code about 3 days after I changed my air filter. Turns out the pcv intake (I think that's what it is anyway) that presses into the side of the intake duct got knocked loose. I was relieved that's all it was .
Old Dec 16, 2013 | 06:48 AM
gr4v3y4rd's Avatar
Thanks guys, i forget to mention MAF and PCV is the first one I look at, I change PCV valve too. I clean the valve solenoid intake too.There is no other codes just P0171, meanwhile I do the live data test with the scanner and everything is Ok. MAP,MAF,O2 everything works properly.Dont what to do know.could it be just adjusting the valves clearance? thanks again.
500$accord
Oct 25, 2010 09:21 AM
maniek
Aug 11, 2010 11:05 AM
cheegum
Apr 7, 2008 08:22 AM
hotppeper33
Mar 8, 2008 06:25 AM
fiji06si13
Sep 4, 2007 10:56 PM
