need help: washer fluid frozen in mn
Old Dec 19, 2009 | 08:55 AM
de_shadows
Default need help: washer fluid frozen in mn
forgot to change the plain water washer fluid i had during the summer and now it's frozen. managed to get the frozen ice out and refilled with appropriate washer, but nothing seems to be working except the wipers.
questions:
-could it be a bad fuse? where is this fuse located?
-could it be a bad motor?
please help and thanks in advance!
~1997 honda accord 4dr~
Old Dec 19, 2009 | 08:27 PM
finch13's Avatar
Feel the lines on the underside of the hood, if they're hard, they're frozen.
Washer fluid pump is probably in the under dash fuse box on the driver's side. The cover has a label with their locations. You could also have someone operate the washer switch while you listen near the driver's side wheel at the bumper. If the pump is trying to move, it should hum. New washer pumps are about $30 - $45 before tax from the dealer, call around first. I like Buerkle, but they seemed priced high last time I was there.
Park in a enclosed garage, heat the pump and the lines with a hair dryer. A heat gun will melt the plastic. The pump is located behind the bumper and the splash shield, so it's a bit tricky to get to. If you can't get access to it, park in any attached garage (it's been warm(er) here, so it should stay above freezing).
Old Feb 1, 2012 | 06:20 PM
Fabb Capo's Avatar
can i get a diagram of the washer fluid hose for the 2004 honda accord? I dont know why mine isnt working I hear the noise when i try and use it its just that nothing comes out, are the hoses visible on a 2004 honda accord?
Old Feb 2, 2012 | 06:57 AM
Looks pretty simple, just one hose until it splits under the cowling. Thing is, you might have to dismantle the cowling in order to see the parts inside the dotted line.
ChappyBob
Oct 27, 2016 05:44 PM
"974thAccord"
May 20, 2011 01:09 PM
AccordinPA
Jan 3, 2010 01:02 PM
zann121
Jun 22, 2009 02:20 PM
bougie_44
Oct 16, 2007 08:01 AM
