Need to set hot/cold climate control manually
Old May 18, 2012 | 02:56 PM
93Accord2.2's Avatar
Default Need to set hot/cold climate control manually
I guess there is a cable? The hot/cold control feels like it's difficult to turn and will only do heat, now... Where can I access the thing that changes it back to cold?? I'd like to set it by hand and just leave it on cold.... thanks!!!
Old May 18, 2012 | 03:24 PM
crispin's Avatar
Look on the firewall almost in the middle but on the passenger side.
Old May 18, 2012 | 03:34 PM
I took the glove box out and was able to get to some little thing I can't see... followed the cable to that, and that did it
Then, I used a coat hanger to adjust the heater control valve but I don't think that was necessary
Old May 18, 2012 | 03:39 PM
You should check the valve and cable from the engine compartment. See that the cable is attached properly. See this link, which should be similar to your model year:
http://autorepair.about.com/library/...bl303a-lib.htm
ModestMitch
Apr 18, 2008 11:05 AM
greenbean
Sep 21, 2007 03:14 PM
coolgmslife
Jul 10, 2007 10:16 AM
