Need to set hot/cold climate control manually
I guess there is a cable? The hot/cold control feels like it's difficult to turn and will only do heat, now... Where can I access the thing that changes it back to cold?? I'd like to set it by hand and just leave it on cold.... thanks!!!
I took the glove box out and was able to get to some little thing I can't see... followed the cable to that, and that did it
Then, I used a coat hanger to adjust the heater control valve but I don't think that was necessary
You should check the valve and cable from the engine compartment. See that the cable is attached properly. See this link, which should be similar to your model year:
http://autorepair.about.com/library/...bl303a-lib.htm
djaaronj
06-20-2013 12:11 PM
liam71234
11-01-2007 07:45 PM
greenbean
09-21-2007 03:14 PM
