new cv = shake
Old Sep 3, 2012 | 03:37 PM
mconlon's Avatar
Default new cv = shake
i have a 94 accord ex.
after replacing the drivers side cv axle my car is shaking violently. under inspection it seems like the new axle is too long. when i turn the wheel all the way to the left it will stop shaking. my motor mounts are clearly worn and the whole engine is shaking under acceleration. i already took back one axle and replaced it with a different one, however it only got worse. could the axle be too long? i purchased a reman master pro from oreilly auto.
symptoms
car shakes with rotation of wheel not by rpm
car goes faster- shake is more frequent
it stops shaking when wheel is turned completely to the right
engine shakes not wheel
new cv axle
cv seems too long
Old Sep 3, 2012 | 04:44 PM
Dr. Drivability's Avatar
wrong or defective axle is my guess....
Old Sep 4, 2012 | 05:54 PM
Need to think about replacing the mounts if they are bad.
Old Sep 4, 2012 | 09:24 PM
My experience is that none of the AZ, ORielly, et al CV axles have the mid-shaft harmonic balancers. I struggled for almost 2 yrs w/ vibration under acceleration of my 94EX (2 replacements w/ AZ axles) before purchasing some Raxles cv axles which include the harmonic balancer rings on the axle.
Raxles cost a bit more (roughtly twice AZ axles) but were worth it for me.
Old Sep 4, 2012 | 09:40 PM
i was going to mention the vibration dampners, also didn't see his motor mounts are wiped out...need those fixed as well.
JackP
Oct 15, 2007 10:28 PM
ssc280
Apr 27, 2007 10:13 PM
92Inspire
Aug 8, 2006 04:07 AM
wth71
Jun 29, 2005 03:02 PM
